IFTTT: How to Parameterised webhooks with google assistant ?
Alexa, Google Home and Siri
RapTile
Post by RapTile »
I want to tell my google assistant to change my TV input channel to HDMI1 or Netflix etc.
And i want IFTTT to send the correct command to Domoticz.
How can i make this possible?
The code below wont work because Set%20Level expects a number.
If You say "change tv input chanel to $", then Make a web request:
https://<username>:<password>@<URL>:<PORT>/json.htm?type=command&param=switchlight&idx=<ID>&switchcmd=Set%20Level&level={{TextField}}
The lvl expects a number instead of text so i am wondering how this could be made possible.
the above code works for changing the TV volume but not switching the input because the volume is a number but the input channel is text.
I know the numbers that are being used by the TV API but i want to tell my google home to to switch an input channel instead of a number.
Thanks in advance for the support.
axel2906
Domoticz version: V3.8926
Re: IFTTT: How to Parameterised webhooks with google assistant ?
Post by axel2906 »
Did you find a solution to your problem ?
I've the same issue. I made 5 request but i want to do like you.
RPi3 - RfxComm - Milight - OWL160
Soepgroenten
Post by Soepgroenten »
One important thing...you need to encode your username and password...otherwise domoticz wont accept it..
Please take a look here for explanation.
https://www.domoticz.com/wiki/Domoticz_ ... horization
In short:
Just encode your username and password on this link, and copy/paste the results in your URL's
https://codebeautify.org/base64-encode
