Switch off smoke detector FA20RF  [Solved]
jandirkv
Domoticz version: 3.9117
Post by jandirkv »
Hallo,
I have a FA20RF smoke detector Setup in Domoticz as 'smoke detector' device. When I activate the switch the FA20RF starts beeping. or with dzvents code
domoticz.devices('Rookmelder hal').switchOn()
Somehow I can not turn it off anymore. I tried the following lines.
domoticz.devices('Rookmelder hal').switchOff()
I can turn it off by pressing the reset button in domoticz in the switches panel. So I tried
domoticz.devices('Rookmelder hal').reset()code]
and
[code]domoticz.devices('Rookmelder hal').state == 'reset'
and
domoticz.devices('Rookmelder hal').state = reset
Also my smoke detector does not always respond to the 'On' action of my RFlink which is a few feet Away from my smoke detector. If it started beeping is responds only after a while again on the 'On' Command.
Has anyone succefully integrated his smoke detectors??
Re: Switch off smoke detector FA20RF
jandirkv wrote: Sunday 21 October 2018 11:18 Hallo,
There is no device-adapter for the switchType smokeDetector defined in dzVents yet. Until then you can use this dzVents script to reset the state of a smoke detector.
            on   = { timer = { "every minute"}},
            logging =   {   level   =   domoticz.LOG_DEBUG,
            marker  =   "reset Security" },
    execute = function(dz)
        mySmokeDetector = 1107                              -- Change this to the idx of your smokeDetector
        local function resetSmokeDetector(idx)
            local  url   = dz.settings['Domoticz url'] ..
                           "/json.htm?type=command&param=resetsecuritystatus&idx=" ..
                           idx ..
                           "&switchcmd=Normal"
            dz.openURL(url)
        resetSmokeDetector(mySmokeDetector)
If the RFlink sends the commands like normal there is probably not much domoticz can do to influence this behavior.
Send you a PM
sincze
Domoticz version: 2024.4
Post by sincze »
Correct, had the issue while pairing. Have to send the command multiple times to trigger the device with RFLINK.
As i don't have DZvents enabled at my parents home I had to dust off the old LUA skills.
if ( ((devicechanged['Melder 1'] == 'On') or
     (devicechanged['Melder 2'] == 'On') or
     (devicechanged['Melder 3'] == 'On') ) and (uservariables["Brandalarm"] == 'False') )
then
	print('<font color="red">### Brandalarm.</font>')
	os.execute (notify_telegrambot)
    if (otherdevices['Melder 1'] ~= 'On') then commandArray['Melder 1']="On FOR 4 SECONDS REPEAT 3 INTERVAL 4 SECONDS" end -- Woonkamer
    if (otherdevices['Melder 2'] ~= 'On') then commandArray['Melder 2']="On FOR 4 SECONDS REPEAT 3 INTERVAL 4 SECONDS" end -- Overloop
    if (otherdevices['Melder 3'] ~= 'On') then commandArray['Melder 3']="On FOR 4 SECONDS REPEAT 3 INTERVAL 4 SECONDS" end -- Zolder
    commandArray['Variable:Brandalarm']=tostring('True')
elseif ((devicechanged['Melder 1'] == 'Off') or
        (devicechanged['Melder 2'] == 'Off') or
        (devicechanged['Melder 3'] == 'Off') )
then
        if (otherdevices['Melder 1'] ~= 'Off') then commandArray['Melder 1']="Off" end -- Woonkamer
        if (otherdevices['Melder 2'] ~= 'Off') then commandArray['Melder 2']="Off" end -- Overloop
        if (otherdevices['Melder 3'] ~= 'Off') then commandArray['Melder 3']="Off" end -- Zolder
        commandArray['Variable:Brandalarm']=tostring('False')
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
pvklink
Domoticz version: latest b
Post by pvklink »
Is there a function in the meantime in dzvents to set the reset of a smope detector. After my alarm went of i automaticly want to reset it when pushing the all alarm button (radio, light etc.)
otherwise i use the workaround
Jablotron connection, Ikea
pvklink wrote: Saturday 06 July 2019 11:22 Is there a function in the meantime in dzvents to set the reset of a smope detector. After my alarm went of i automaticly want to reset it when pushing the all alarm button (radio, light etc.)
The device-adapter is created but after I asked Jan Dirk to test it he never replied and he does not seem to be active any longer on this forum.
If you want to test the device-adapter. Here it is. Just save it as <domoticz dir>/dzVents/runtime/device-adapters/smokeDetector_device.lua and control your smoke detector with methods activate() and reset()
    baseType = 'device',
    name = 'Smoke Detector device adapter',
    matches = function (device, adapterManager)
        local res = device.switchType == 'Smoke Detector'
        adapterManager.addDummyMethod(device, 'activate')
        adapterManager.addDummyMethod(device, 'reset')
        return res
    end,
    process = function (device, data, domoticz, utils, adapterManager)
        if (device.switchType == 'Smoke Detector') then
            function device.reset()
                local url
                url = domoticz.settings['Domoticz url'] ..
                        device.id ..
                        "&switchcmd=Normal"
                return domoticz.openURL(url)
            function device.activate()
                local TimedCommand = require('TimedCommand')
                return TimedCommand(domoticz, device.name, 'On', 'device', device.state)
pvklink
Post by pvklink »
Ok, i will test it and give feedback!
pvklink
Post by pvklink »
OK, did it..
added the file on
Made a test file with
dz.devices('smoke_trap').reset() -- reset smoke detectors
dz.devices('smoke_hal').reset() -- reset smoke detectors
globalMessage(add, ' smoke devices gereset',logcode) -- write to logs
globalMessage(chg) -- dump
error (probl. did something wrong.
2019-07-07 09:41:12.104 Error: dzVents: Error: (2.4.24) An error occurred when calling event handler OFF_DZ_test_msg
2019-07-07 09:41:12.104 Error: dzVents: Error: (2.4.24) ...cz/scripts/dzVents/generated_scripts/OFF_DZ_test_msg.lua:41: attempt to call field 'reset' (a nil value)
2019-07-07 09:41:14.114 (zwavepluspvk) General/kWh (buro_kwh)
2
Re: Switch off smoke detector FA20RF  [Solved]
pvklink wrote: Sunday 07 July 2019 9:45 OK, did it..
added the file on
2
Send a PM
