I recently switched from raspi to synology. I m looking for a way to continue to use my 1-wire sensors, and came across this device.
https://www.ebay.com/itm/USB-1-wire-1wi ... SwMfhaVMAQ
does anyone has this successfully working, or knows that it will or won't work? And if not, are there any alternative solutions?
Synology and 1-wire
Moderators: fantom, leecollings
Jumper3126
SweetPants
Re: Synology and 1-wire
I don't see any 1-wire hardware with USB in the hardware list, so I think you are out of luck. Maybe you can add a rpi slave domoticz server and add 1-wire to that?
gerardvs
- Domoticz version: latest-1
You also could use an Arduino (e.g. Nano) as a Mysensors gateway without radio and connect the 1-wire sensors to the gateway. A few euro/dollar solution.
