I'm currently running the latest stable on port 8080 of a raspberry pi.
But I would like to be able to also run a beta version on the same machine, and be able to switch between them easily. My thoughts are to run the beta version on a different port.
Aside form the port, I guess it would be best to install the beta in a separate directory, such as 'domoticz-beta'.
Is this do-able, and advisable?
Can the stable and beta version of domoticz be run on the same machine?
- leecollings
gordonb3
- Domoticz version: Custom
Re: Can the stable and beta version of domoticz be run on the same machine?
In theory, yes. You're likely to find that connecting both instances to the same hardware will be troublesome or (close to) impossible though.
