If does work for on but not for off
niwreg
Post by niwreg »
The goal: do some smart things with lighting when we are home or not.
		timer = {
		    '60 minutes before sunset',
		     'at 22:45'
	logging = {
        level = domoticz.LOG_DEBUG,
        marker = "LightAtDusk: "
	execute = function(d, triggers)
	    logtekst = ''
	    d.log('The rule that triggered the event was: ' .. triggers.trigger)
	    logtekst = logtekst .. 'The rule that triggered the event was: ' .. triggers.trigger .. '\r\n'
	    --check if somebody home so
	    d.log("Somebody status: " .. d.devices(15).state);
	    logtekst = logtekst .. "Somebody status: >" .. d.devices(15).state .. '< \r\n'
	    if triggers.trigger == '60 minutes before sunset'  then
	        d.notify('Remote Debug','Ik trigger wel maar negeer de status ')
	        d.notify('Remote Debug', d.devices(15).state)
	        logtekst = logtekst .. "Inside 60 minutes before " .. '\r\n'
    	    if d.devices(15).state == "On" then
    	        logtekst = logtekst .. "Switch on? somebody home " .. '\r\n'
    	        --somebody is home! Allrighty check for lights and switch them on.
    	        --No using scenes because i now we can use the checkFirst function to see if some lights *kuch*  (433 mhz devices) all already on.
    	        d.devices(36).switchOn()
    	    --end
            elseif d.devices(15).state == "Off" then
                d.notify('Remote debug','Er is niemand thuis  ')
                logtekst = logtekst .. "Switch on? nobody home " .. '\r\n'
                -- switch on the lights
                d.variable('FullAutoLights').set('1')
                d.devices(36).switchOn().checkFirst()
                d.notify('Domoticz!!','Blinde paniek er is onbekend of er iemand thuis is  ')
	    if triggers.trigger == 'at 22:45' and domoticz.variables('FullAutoLights').value == '1' then
	         logtekst = logtekst .. "Inside at22:45 Switch off? nobody home " .. '\r\n'
	        d.variable('FullAutoLights').set('0')
            d.devices(36).switchOff().checkFirst()
        d.log(logtekst)
	   d.notify('Remote Debug!',logtekst)
Device with IDX 15 is a dummy on/off switch. When somebody is home and the switch is On everythings works ok.
But when there is nobody home it doesn't get through the "er is niemand thuis" part. It only gets into the 60 minutes before sunset part.
Am i making an huge beginners fault or is there something i'm complelty missing?
Re: If does work for on but not for off
niwreg wrote: Sunday 14 October 2018 20:24 The goal: do some smart things with lighting when we are home or not.
Am I making an huge beginners fault or is there something i'm completely missing?
you pass the domoticz object to your execute = function as "d" but in line
you try to get the value from uservariable "FullAutolights" from "domoticz" I would not be surprised if that is nil, causing the evaluation of this if statement to be always false. Changing this line to
if triggers.trigger == 'at 22:45' and d.variables('FullAutoLights').value == '1' then
might be the solution.
niwreg
Post by niwreg »
waaren wrote: Sunday 14 October 2018 22:21
That was possible the next thing i was going run into.
But i keep having troubles with the at hour before sunset espacialy this line:
This never validates as true although when i look in the current states list of the events this is the result:
15	Somebody Home	Off	2018-10-14 16:56:07	0
Not sure if I understand but your timer is now telling dzVents to execute once at 60 minutes before sunset and at 22:45.
Do you want that or do you want: "every minute between 60 minutes before sunset and sunset" and "at 22:45" ?
niwreg
Post by niwreg »
No the timer is ok.
I want to switch on the light an hour before sunset and switch a few of at 22:45
However depening if we are at home or not i want to switch some other lights as wel. But thati can't get that if to get to work.
Edit:
I created an debug version of the script and will see of this does work or that i run into some other problems.
		timer = {
		     'at 22:45'
	logging = {
        marker = "DebugLight: "
	        d.log('Inside 60Minutes if')
    	        d.log('And the device 15 is on')
                d.log('But the device 15 is off')
                d.log('But the device 15 is not known')
        d.log(logtekst)
I made sure that the somebody home switch is manualy controlled so that is off at the moment
niwreg
Post by niwreg »
Ok i found the error.
it's variables instead of variable
The program would crash on this line so there would be no ligts switched on
