New Xiaomi Gateway v3 - not supported? (unhandled model: acpartner.v3)
yaroz79
Post by yaroz79 »
Hi.
Is it possible to use OpenHAB with new Xiomi Gateway (called “Xiaomi Aqara Air Conditioning Companion” or “Mi Gateway 3”) model lumi.acpartner.v3
https://xiaomi-mi.com/sockets-and-senso ... ty-sensor/
I own this device and it works very well as a gateway with my Xiomi Aquara sensors (motion, temperature, door).
This is info from Mi Home android app:
Version code:204
网关ID:93869871
Zigbee通道:15
网关信息:
{“life”:56497,“cfg_time”:0,“token”:“4f52ea09465XXXXXXXXXXXXXXXX”,“mac”:“7C:49:EB:XXXXXXXXX”,“fw_ver”:“1.4.1_152”,“hw_ver”:“MW300”,“model”:“lumi.acpartner.v3”,“mcu_fw_ver”:“0149”,“wifi_fw_ver”:“SD878x-14.76.36.p84-702.1.0-WM”,“ap”:{“rssi”:-49,“ssid”:“pajonk”,“bssid”:“18:D6:XXXXXXXXX1”},“netif”:{“localIp”:“192.168.2.227”,“mask”:“255.255.255.0”,“gw”:“192.168.2.1”,“gw_mac”:“18:XXXXXXXX”},“mmfree”:144248,“ot”:“ott”,“otu_stat”:[573,383,647,20,622,92],“ott_stat”:[2,0,753,296]}
子设备信息:
[{“model”:“lumi.sensor_magnet.aq2”,“did”:“lumi.158d00XXXXXXX”,“name”:“Aqara
Door and Window
Sensor”},{“model”:“lumi.sensor_motion.aq2”,“did”:“lumi.158d000XXXXXXX”,“name”:“Aqara
Motion
Sensor”},{“model”:“lumi.weather.v1”,“did”:“lumi.158d000XXXXXXXX”,“name”:“Temperature
and Humidity Sensor”}]
I was able to activate LAN functions and get the key via Mi Home android app.
Despite this, i cannot make my gateway to work with Domoticz. The log shows:
2018-10-12 20:41:45.645 Status: XiaomiGateway: unhandled model: acpartner.v3
2018-10-12 20:41:55.624 Status: XiaomiGateway: unhandled model: acpartner.v3
2018-10-12 20:42:05.605 Status: XiaomiGateway: unhandled model: acpartner.v3
2018-10-12 20:42:15.590 Status: XiaomiGateway: unhandled model: acpartner.v3
Thank you for any help.
Best regards.
ak97
Domoticz version: latest
Re: New Xiaomi Gateway v3 - not supported? (unhandled model: acpartner.v3)
Post by ak97 »
in domoticz, create a user variable:
XiaomiMessage, Integer, 1
restart domoticz and show logs
salvacalatayud
Post by salvacalatayud »
Any idea on how to make it work?
ak97
Post by ak97 »
emiel
Post by emiel »
Hi ak97,
Please take a look at this log file. It contains both a heartbeat from the gateway(v3) as well as a report from a motion sensor.
2018-12-12 21:16:21.588 Status: XiaomiGateway: will listen on 9898 for hardware id 7
2018-12-12 21:16:21.589 Status: XiaomiGateway: Delaying worker startup...
2018-12-12 21:16:26.589 Status: XiaomiGateway: Worker started...
2018-12-12 21:16:26.590 Status: XiaomiGateway: Using xxx.xxx.xxx.xxx for local IP address.
2018-12-12 21:16:26.622 Status: XiaomiGateway: unhandled model: acpartner.v3
2018-12-12 21:16:26.622 Status: {"cmd":"heartbeat","model":"acpartner.v3","sid":"xxxxxxxxxxxx","token":"qlbE37unyf7KGXQp","params":[{"ip":"xxx.xxx.xxx.xxx"}]}
2018-12-12 21:16:36.597 Status: XiaomiGateway: unhandled model: acpartner.v3
2018-12-12 21:16:36.597 Status: {"cmd":"heartbeat","model":"acpartner.v3","sid":"xxxxxxxxxxxx","token":"usZgAU0UOH9mPkh8","params":[{"ip":"xxx.xxx.xxx.xxx"}]}
2018-12-12 21:16:41.906 Status: {"cmd":"report","model":"sensor_motion.aq2","sid":"xxxxxxxxxxxxxx","params":[{"illumination":13},{"lux":13}]}
2018-12-12 21:16:41.952 Status: {"cmd":"report","model":"sensor_motion.aq2","sid":"xxxxxxxxxxxxxx","params":[{"motion_status":"motion"}]}
It's also discussed here: https://github.com/domoticz/domoticz/issues/2310
ak97
Post by ak97 »
