Can someone explain what it would need to Domoticz support RuuviTag sensors? RuuviTag seems to be very accurate.
https://shop.ruuvi.com/product/ruuvitag/
RuuviTag is using calibrated Bosch BME280 environmental sensor. Measures temperature, relative humidity and air pressure.
https://www.bosch-sensortec.com/bst/pro ... cts/bme280
Python library for communicating with RuuviTag BLE Sensor Beacon and for decoding sensor data from broadcasted eddystone-url.
https://github.com/ttu/ruuvitag-sensor
RuuviTag sensors (Bosch BME280 environmental sensor)
mpx2
- Domoticz version: 4.10717
antwan
- Domoticz version: Latest
Re: RuuviTag sensors (Bosch BME280 environmental sensor)
Domoticz allready supports BME280.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
mpx2
How do I connect that to Domoticz and Raspberry Pi? I need wireless sensors without external power supply.
antwan
Mysensors?
I have python script for conection with domoticz. But in my tests is RuviTag quite inacurate...
mpx2
Seems that RuuviTag's reaction time is very slow. You need to open the enclosure or otherwise it takes ages to reach the right temperature and escpecially humidity.devros wrote: Saturday 13 October 2018 9:42 I have python script for conection with domoticz. But in my tests is RuviTag quite inacurate...
https://blog.ruuvi.com/humidity-sensor-673c5b7636fc
mpx2
There are many reports that Bosch BME280 is not accurate for temperature measurements.devros wrote: Saturday 13 October 2018 9:42 I have python script for conection with domoticz. But in my tests is RuviTag quite inacurate...
Temperature measured by the internal temperature sensor. This temperature value depends on the PCB temperature, sensor element self-heating and ambient temperature and is typically above ambient temperature.
https://www.mouser.com/datasheet/2/783/ ... 509607.pdf
Looks like the only thing RuuviTag is suitable is pressure measurements.
