dzvents script does not trigger
manjh
Post by manjh »
I am very sure this is a solid user error on my side, but I have been staring at this for a while and simply donot see what is wrong.
I want to create a dzvents script that is triggered every minute.
Using the Domoticz editor, I created a script:
Name "test", type "dzVents", triggered by "all" (I also tried "timer")
Code could not be simpler:
	active = true,
		['timer'] = 'every 1 minutes'
	execute = function(domoticz)
		domoticz.log('@@@@@@@@@@@@@@@@@@@@@@@@@@ test', domoticz.LOG_INFO)
I expect to see the line of text every minute, but nothing happens.
Checked in Setup-->Settings-->Other: dzVents is enabled, log is on "Errors+forced messages".
As said, I am sure I am missing something but I don't see it.
Help?
Hans
dannybloe
Re: dzvents script does not trigger
Post by dannybloe »
Please look at the timer examples in the documentation carefully. You have to use the proper syntax:
    timer = { 'every minute' }
manjh
Post by manjh »
dannybloe wrote: Monday 08 October 2018 19:22 Please look at the timer examples in the documentation carefully. You have to use the proper syntax:
Thanks, makes sense. It was a user error, but in my defense: I "borrowed" a script from the forum and inherited the error... :mrgreen:
It now stumbles over this statement:
local minutes = domoticz.devices[name].lastUpdate.minutesAgo
Error is "attempt to index field 'devices' (a function value)".
Hans
manjh
Post by manjh »
Sorry, got it. Similar mistake.
This one works:
local minutes = domoticz.devices(name).lastUpdate.minutesAgo
Hans
