lastUpdate nil value
Posted: Sunday 07 October 2018 22:03
by jannnfe
I just wanted to test the following code snippets from the dzVents Wiki
https://www.domoticz.com/wiki/DzVents:_ ... _iterators in my system, but it does not work for me:
local deadDevices = domoticz.devices().filter(function(device)
return (device.lastUpdate.minutesAgo > 60)
end)
deadDevices.forEach(function(zombie)
-- do something
end)
The log outputs:
2018-10-07 21:59:00.119 Status: dzVents: Error (2.4.7): ManageBattery: ...ticz/scripts/dzVents/generated_scripts/ManageBattery.lua:22: attempt to index field 'lastUpdate' (a nil value)
Is this a bug? Is this a bug only in my system?
Re: lastUpdate nil value
Posted: Sunday 07 October 2018 23:44
by waaren
Seems to be something is not right here. If I execute this
on = { timer = { "every minute"}},
logging = { level = domoticz.LOG_INFO,
marker = "testiteration" },
execute = function(domoticz)
local myDevice
local deadDevices = domoticz.devices().filter(function(myDevice)
if myDevice.lastUpdate ~= nil then
return (myDevice.lastUpdate.hoursAgo > 1 )
domoticz.log("Device ".. myDevice.name .. " (idx: " .. myDevice.idx .. ") has no lastUpdate set !?!?",domoticz.LOG_ERROR)
end)
domoticz.log("Device ".. zombie.name .. " is not updated during the last 60 minutes",domoticz.LOG_INFO)
end)
the log shows...
2018-10-07 23:27:00.764 Status: dzVents: Info: testiteration: ------ Start external script: testIteration.lua:, trigger: every minute
2018-10-07 23:27:00.767 Status: dzVents: Error (2.4.7): testiteration: Device (idx: 0) has no lastUpdate set !?!?
2018-10-07 23:27:00.768 Status: dzVents: Error (2.4.7): testiteration: Device (idx: 0) has no lastUpdate set !?!?
2018-10-07 23:27:01.053 Status: dzVents: Info: testiteration: Device km1 is not updated during the last 60 minutes
2018-10-07 23:27:01.053 Status: dzVents: Info: testiteration: Device XMotion-1 is not updated during the last 60 minutes
2018-10-07 23:27:01.055 Status: dzVents: Info: testiteration: Device XMotion-6 is not updated during the last 60 minutes
2018-10-07 23:27:01.056 Status: dzVents: Info: testiteration: Device km3 is not updated during the last 60 minutes
2018-10-07 23:27:01.057 Status: dzVents: Info: testiteration: Device Xiaomi Gateway Alarm Ringtone is not updated during the last 60 minutes
2018-10-07 23:27:01.057 Status: dzVents: Info: testiteration: Device My_External_IP is not updated during the last 60 minutes
2018-10-07 23:27:01.064 Status: dzVents: Info: testiteration: ------ Finished testIteration.lua
So dzVents return some ghost devices. I checked the database but no ghost devices in deviceStatus table. I checked with a myDevice.dump() statement but that does only return empty fields.
Hope @dannybloe can answer / fix this one
Posted: Monday 08 October 2018 6:50
by dannybloe
Mm... interesting.. Perhaps you can do an attribute dump (device.dump()) for these devices and see what they are.
Reading from the code, devices that do not get lastUpdate information from Domoticz should be discarded (with a debug-level log message in the log).
Posted: Monday 08 October 2018 7:30
by waaren
dannybloe wrote: Monday 08 October 2018 6:50
@dannybloe, did do the attribute dump but everything empty
- Spoiler: show
[code]2018-10-08 07:27:00.692 Status: dzVents: > kodiSetVolume()
2018-10-08 07:27:00.692 Status: dzVents: > increaseBrightness()
2018-10-08 07:27:00.692 Status: dzVents: > open()
2018-10-08 07:27:00.692 Status: dzVents: > updateTempBaro()
2018-10-08 07:27:00.692 Status: dzVents: > kodiPause()
2018-10-08 07:27:00.692 Status: dzVents: > updateUV()
2018-10-08 07:27:00.692 Status: dzVents: > updateHumidity()
2018-10-08 07:27:00.692 Status: dzVents: > switchSelector()
2018-10-08 07:27:00.692 Status: dzVents: > updateMode()
2018-10-08 07:27:00.692 Status: dzVents: > kodiSwitchOff()
2018-10-08 07:27:00.692 Status: dzVents: > updateTempHum()
2018-10-08 07:27:00.692 Status: dzVents: > play()
2018-10-08 07:27:00.692 Status: dzVents: > decreaseBrightness()
2018-10-08 07:27:00.692 Status: dzVents: > updateSetPoint()
2018-10-08 07:27:00.692 Status: dzVents: > name:
2018-10-08 07:27:00.692 Status: dzVents: > updateDistance()
2018-10-08 07:27:00.692 Status: dzVents: > armHome()
2018-10-08 07:27:00.692 Status: dzVents: > setNightMode()
2018-10-08 07:27:00.693 Status: dzVents: > updatePercentage()
2018-10-08 07:27:00.693 Status: dzVents: > setVolume()
2018-10-08 07:27:00.693 Status: dzVents: > setRGB()
2018-10-08 07:27:00.693 Status: dzVents: > kodiStop()
2018-10-08 07:27:00.693 Status: dzVents: > updateElectricity()
2018-10-08 07:27:00.693 Status: dzVents: > setDiscoMode()
2018-10-08 07:27:00.693 Status: dzVents: > setKelvin()
2018-10-08 07:27:00.693 Status: dzVents: > _adapters:
2018-10-08 07:27:00.693 Status: dzVents: > updateWind()
2018-10-08 07:27:00.693 Status: dzVents: > updateSoilMoisture()
2018-10-08 07:27:00.693 Status: dzVents: > updateVoltage()
2018-10-08 07:27:00.693 Status: dzVents: > updateGas()
2018-10-08 07:27:00.693 Status: dzVents: > armAway()
2018-10-08 07:27:00.693 Status: dzVents: > updateBarometer()
2018-10-08 07:27:00.693 Status: dzVents: > updateRain()
2018-10-08 07:27:00.693 Status: dzVents: > updateWeight()
2018-10-08 07:27:00.693 Status: dzVents: > onkyoEISCPCommand()
2018-10-08 07:27:00.693 Status: dzVents: > startPlaylist()
2018-10-08 07:27:00.693 Status: dzVents: > updateSoundLevel()
2018-10-08 07:27:00.693 Status: dzVents: > updateAirQuality()
2018-10-08 07:27:00.693 Status: dzVents: > updateLux()
2018-10-08 07:27:00.694 Status: dzVents: > update()
2018-10-08 07:27:00.694 Status: dzVents: > disarm()
2018-10-08 07:27:00.694 Status: dzVents: > setWhiteMode()
2018-10-08 07:27:00.694 Status: dzVents: > _data:
2018-10-08 07:27:00.694 Status: dzVents: > switchType: On/Off
2018-10-08 07:27:00.694 Status: dzVents: > name:
2018-10-08 07:27:00.694 Status: dzVents: > lastUpdate:
2018-10-08 07:27:00.694 Status: dzVents: > switchTypeValue: 0
2018-10-08 07:27:00.694 Status: dzVents: > signalLevel: 0
2018-10-08 07:27:00.694 Status: dzVents: > lastLevel: 0
2018-10-08 07:27:00.694 Status: dzVents: > id: 0
2018-10-08 07:27:00.694 Status: dzVents: > timedOut: true
2018-10-08 07:27:00.694 Status: dzVents: > subType: Unknown
2018-10-08 07:27:00.694 Status: dzVents: > data:
2018-10-08 07:27:00.694 Status: dzVents: > hardwareID: 0
2018-10-08 07:27:00.694 Status: dzVents: > _state:
2018-10-08 07:27:00.694 Status: dzVents: > _nValue: 0
2018-10-08 07:27:00.694 Status: dzVents: > changed: false
2018-10-08 07:27:00.694 Status: dzVents: > batteryLevel: 0
2018-10-08 07:27:00.694 Status: dzVents: > rawData:
2018-10-08 07:27:00.695 Status: dzVents: > description:
2018-10-08 07:27:00.695 Status: dzVents: > deviceID:
2018-10-08 07:27:00.695 Status: dzVents: > baseType: device
2018-10-08 07:27:00.695 Status: dzVents: > deviceType: Interface Control
2018-10-08 07:27:00.695 Status: dzVents: > updateYouless()
2018-10-08 07:27:00.695 Status: dzVents: > kodiPlayPlaylist()
2018-10-08 07:27:00.695 Status: dzVents: > updateTemperature()
2018-10-08 07:27:00.695 Status: dzVents: > switchOff()
2018-10-08 07:27:00.695 Status: dzVents: > pause()
2018-10-08 07:27:00.695 Status: dzVents: > updateWetness()
2018-10-08 07:27:00.695 Status: dzVents: > kodiPlay()
2018-10-08 07:27:00.695 Status: dzVents: > updateAlertSensor()
2018-10-08 07:27:00.695 Status: dzVents: > updateVisibility()
2018-10-08 07:27:00.695 Status: dzVents: > switchOn()
2018-10-08 07:27:00.695 Status: dzVents: > kodiExecuteAddOn()
2018-10-08 07:27:00.695 Status: dzVents: > playFavorites()
2018-10-08 07:27:00.695 Status: dzVents: > kodiPlayFavorites()
2018-10-08 07:27:00.695 Status: dzVents: > updateCounter()
2018-10-08 07:27:00.695 Status: dzVents: > id: 0
2018-10-08 07:27:00.695 Status: dzVents: > idx: 0
2018-10-08 07:27:00.695 Status: dzVents: > updateWaterflow()
2018-10-08 07:27:00.696 Status: dzVents: > close()
2018-10-08 07:27:00.696 Status: dzVents: > toggleSwitch()
2018-10-08 07:27:00.696 Status: dzVents: > updateText()
2018-10-08 07:27:00.696 Status: dzVents: > updatePressure()
2018-10-08 07:27:00.696 Status: dzVents: > stop()
2018-10-08 07:27:00.696 Status: dzVents: > baseType: device
2018-10-08 07:27:00.696 Status: dzVents: > updateRadiation()
2018-10-08 07:27:00.696 Status: dzVents: > updateCustomSensor()
2018-10-08 07:27:00.696 Status: dzVents: > dimTo()
2018-10-08 07:27:00.696 Status: dzVents: > updateTempHumBaro()
2018-10-08 07:27:00.696 Status: dzVents: > updateP1()
2018-10-08 07:27:00.696 Status: dzVents: > dump()
Posted: Monday 08 October 2018 9:41
by dannybloe
Yes, as you can see data.lastUpdate is indeed nil. Somehow though the device ends up in the collection anyway. I will have to look into that. In the mean time, just check the lastUpdate attribute.
Posted: Wednesday 10 October 2018 11:07
by jannnfe
@dannybloe sorry but what do you mean with just Check the lastUpdate attribute?
What Code i Can use in the meantime to archive the same result?
Re: lastUpdate nil value [SOLVED]
Posted: Wednesday 10 October 2018 12:32
by waaren
jannnfe wrote: Wednesday 10 October 2018 11:07
You can use my example
