lastUpdate nil value  [SOLVED]
jannnfe
Post by jannnfe »
I just wanted to test the following code snippets from the dzVents Wiki https://www.domoticz.com/wiki/DzVents:_ ... _iterators in my system, but it does not work for me:
   local deadDevices = domoticz.devices().filter(function(device)
      return (device.lastUpdate.minutesAgo > 60)
   end)
   deadDevices.forEach(function(zombie)
      -- do something
   end)
The log outputs:
2018-10-07 21:59:00.119 Status: dzVents: Error (2.4.7): ManageBattery: ...ticz/scripts/dzVents/generated_scripts/ManageBattery.lua:22: attempt to index field 'lastUpdate' (a nil value)
Is this a bug? Is this a bug only in my system?
Re: lastUpdate nil value
jannnfe wrote: Sunday 07 October 2018 22:03 I just wanted to test the following code snippets from the dzVents Wiki https://www.domoticz.com/wiki/DzVents:_ ... _iterators in my system, but it does not work for me:
Seems to be something is not right here. If I execute this
        on           = { timer        = {   "every minute"}},
        logging      =   {   level   =   domoticz.LOG_INFO,
                             marker  =   "testiteration" },
    execute = function(domoticz)
        local myDevice
        local deadDevices = domoticz.devices().filter(function(myDevice)
            if myDevice.lastUpdate ~= nil then
                return (myDevice.lastUpdate.hoursAgo > 1 )
                 domoticz.log("Device ".. myDevice.name .. " (idx: " .. myDevice.idx ..   ") has no lastUpdate set !?!?",domoticz.LOG_ERROR)
       end)
          domoticz.log("Device ".. zombie.name .. " is not updated during the last 60 minutes",domoticz.LOG_INFO)
       end)
the log shows...
2018-10-07 23:27:00.764  Status: dzVents: Info:  testiteration: ------ Start external script: testIteration.lua:, trigger: every minute
2018-10-07 23:27:00.767  Status: dzVents: Error (2.4.7): testiteration: Device  (idx: 0) has no lastUpdate set !?!?
2018-10-07 23:27:00.768  Status: dzVents: Error (2.4.7): testiteration: Device  (idx: 0) has no lastUpdate set !?!?
2018-10-07 23:27:01.053  Status: dzVents: Info:  testiteration: Device km1 is not updated during the last 60 minutes
2018-10-07 23:27:01.053  Status: dzVents: Info:  testiteration: Device XMotion-1 is not updated during the last 60 minutes
2018-10-07 23:27:01.055  Status: dzVents: Info:  testiteration: Device XMotion-6 is not updated during the last 60 minutes
2018-10-07 23:27:01.056  Status: dzVents: Info:  testiteration: Device km3 is not updated during the last 60 minutes
2018-10-07 23:27:01.057  Status: dzVents: Info:  testiteration: Device Xiaomi Gateway Alarm Ringtone is not updated during the last 60 minutes
2018-10-07 23:27:01.057  Status: dzVents: Info:  testiteration: Device My_External_IP is not updated during the last 60 minutes
2018-10-07 23:27:01.064  Status: dzVents: Info:  testiteration: ------ Finished testIteration.lua
So dzVents return some ghost devices. I checked the database but no ghost devices in deviceStatus table. I checked with a myDevice.dump() statement but that does only return empty fields.
Hope @dannybloe can answer / fix this one
dannybloe
Post by dannybloe »
Mm... interesting.. Perhaps you can do an attribute dump (device.dump()) for these devices and see what they are.
Reading from the code, devices that do not get lastUpdate information from Domoticz should be discarded (with a debug-level log message in the log).
dannybloe wrote: Monday 08 October 2018 6:50 Mm... interesting.. Perhaps you can do an attribute dump (device.dump()) for these devices and see what they are.
@dannybloe, did do the attribute dump but everything empty
[code]2018-10-08 07:27:00.692  Status: dzVents: > kodiSetVolume()
2018-10-08 07:27:00.692  Status: dzVents: > increaseBrightness()
2018-10-08 07:27:00.692  Status: dzVents: > open()
2018-10-08 07:27:00.692  Status: dzVents: > updateTempBaro()
2018-10-08 07:27:00.692  Status: dzVents: > kodiPause()
2018-10-08 07:27:00.692  Status: dzVents: > updateUV()
2018-10-08 07:27:00.692  Status: dzVents: > updateHumidity()
2018-10-08 07:27:00.692  Status: dzVents: > switchSelector()
2018-10-08 07:27:00.692  Status: dzVents: > updateMode()
2018-10-08 07:27:00.692  Status: dzVents: > kodiSwitchOff()
2018-10-08 07:27:00.692  Status: dzVents: > updateTempHum()
2018-10-08 07:27:00.692  Status: dzVents: > play()
2018-10-08 07:27:00.692  Status: dzVents: > decreaseBrightness()
2018-10-08 07:27:00.692  Status: dzVents: > updateSetPoint()
2018-10-08 07:27:00.692  Status: dzVents: > name:
2018-10-08 07:27:00.692  Status: dzVents: > updateDistance()
2018-10-08 07:27:00.692  Status: dzVents: > armHome()
2018-10-08 07:27:00.692  Status: dzVents: > setNightMode()
2018-10-08 07:27:00.693  Status: dzVents: > updatePercentage()
2018-10-08 07:27:00.693  Status: dzVents: > setVolume()
2018-10-08 07:27:00.693  Status: dzVents: > setRGB()
2018-10-08 07:27:00.693  Status: dzVents: > kodiStop()
2018-10-08 07:27:00.693  Status: dzVents: > updateElectricity()
2018-10-08 07:27:00.693  Status: dzVents: > setDiscoMode()
2018-10-08 07:27:00.693  Status: dzVents: > setKelvin()
2018-10-08 07:27:00.693  Status: dzVents: > _adapters:
2018-10-08 07:27:00.693  Status: dzVents: > updateWind()
2018-10-08 07:27:00.693  Status: dzVents: > updateSoilMoisture()
2018-10-08 07:27:00.693  Status: dzVents: > updateVoltage()
2018-10-08 07:27:00.693  Status: dzVents: > updateGas()
2018-10-08 07:27:00.693  Status: dzVents: > armAway()
2018-10-08 07:27:00.693  Status: dzVents: > updateBarometer()
2018-10-08 07:27:00.693  Status: dzVents: > updateRain()
2018-10-08 07:27:00.693  Status: dzVents: > updateWeight()
2018-10-08 07:27:00.693  Status: dzVents: > onkyoEISCPCommand()
2018-10-08 07:27:00.693  Status: dzVents: > startPlaylist()
2018-10-08 07:27:00.693  Status: dzVents: > updateSoundLevel()
2018-10-08 07:27:00.693  Status: dzVents: > updateAirQuality()
2018-10-08 07:27:00.693  Status: dzVents: > updateLux()
2018-10-08 07:27:00.694  Status: dzVents: > update()
2018-10-08 07:27:00.694  Status: dzVents: > disarm()
2018-10-08 07:27:00.694  Status: dzVents: > setWhiteMode()
2018-10-08 07:27:00.694  Status: dzVents: > _data:
2018-10-08 07:27:00.694  Status: dzVents: >     switchType: On/Off
2018-10-08 07:27:00.694  Status: dzVents: >     name:
2018-10-08 07:27:00.694  Status: dzVents: >     lastUpdate:
2018-10-08 07:27:00.694  Status: dzVents: >     switchTypeValue: 0
2018-10-08 07:27:00.694  Status: dzVents: >     signalLevel: 0
2018-10-08 07:27:00.694  Status: dzVents: >     lastLevel: 0
2018-10-08 07:27:00.694  Status: dzVents: >     id: 0
2018-10-08 07:27:00.694  Status: dzVents: >     timedOut: true
2018-10-08 07:27:00.694  Status: dzVents: >     subType: Unknown
2018-10-08 07:27:00.694  Status: dzVents: >     data:
2018-10-08 07:27:00.694  Status: dzVents: >         hardwareID: 0
2018-10-08 07:27:00.694  Status: dzVents: >         _state:
2018-10-08 07:27:00.694  Status: dzVents: >         _nValue: 0
2018-10-08 07:27:00.694  Status: dzVents: >     changed: false
2018-10-08 07:27:00.694  Status: dzVents: >     batteryLevel: 0
2018-10-08 07:27:00.694  Status: dzVents: >     rawData:
2018-10-08 07:27:00.695  Status: dzVents: >     description:
2018-10-08 07:27:00.695  Status: dzVents: >     deviceID:
2018-10-08 07:27:00.695  Status: dzVents: >     baseType: device
2018-10-08 07:27:00.695  Status: dzVents: >     deviceType: Interface Control
2018-10-08 07:27:00.695  Status: dzVents: > updateYouless()
2018-10-08 07:27:00.695  Status: dzVents: > kodiPlayPlaylist()
2018-10-08 07:27:00.695  Status: dzVents: > updateTemperature()
2018-10-08 07:27:00.695  Status: dzVents: > switchOff()
2018-10-08 07:27:00.695  Status: dzVents: > pause()
2018-10-08 07:27:00.695  Status: dzVents: > updateWetness()
2018-10-08 07:27:00.695  Status: dzVents: > kodiPlay()
2018-10-08 07:27:00.695  Status: dzVents: > updateAlertSensor()
2018-10-08 07:27:00.695  Status: dzVents: > updateVisibility()
2018-10-08 07:27:00.695  Status: dzVents: > switchOn()
2018-10-08 07:27:00.695  Status: dzVents: > kodiExecuteAddOn()
2018-10-08 07:27:00.695  Status: dzVents: > playFavorites()
2018-10-08 07:27:00.695  Status: dzVents: > kodiPlayFavorites()
2018-10-08 07:27:00.695  Status: dzVents: > updateCounter()
2018-10-08 07:27:00.695  Status: dzVents: > id: 0
2018-10-08 07:27:00.695  Status: dzVents: > idx: 0
2018-10-08 07:27:00.695  Status: dzVents: > updateWaterflow()
2018-10-08 07:27:00.696  Status: dzVents: > close()
2018-10-08 07:27:00.696  Status: dzVents: > toggleSwitch()
2018-10-08 07:27:00.696  Status: dzVents: > updateText()
2018-10-08 07:27:00.696  Status: dzVents: > updatePressure()
2018-10-08 07:27:00.696  Status: dzVents: > stop()
2018-10-08 07:27:00.696  Status: dzVents: > baseType: device
2018-10-08 07:27:00.696  Status: dzVents: > updateRadiation()
2018-10-08 07:27:00.696  Status: dzVents: > updateCustomSensor()
2018-10-08 07:27:00.696  Status: dzVents: > dimTo()
2018-10-08 07:27:00.696  Status: dzVents: > updateTempHumBaro()
2018-10-08 07:27:00.696  Status: dzVents: > updateP1()
2018-10-08 07:27:00.696  Status: dzVents: > dump()
dannybloe
Post by dannybloe »
Yes, as you can see data.lastUpdate is indeed nil. Somehow though the device ends up in the collection anyway. I will have to look into that. In the mean time, just check the lastUpdate attribute.
jannnfe
Post by jannnfe »
@dannybloe sorry but what do you mean with just Check the lastUpdate attribute?
What Code i Can use in the meantime to archive the same result?
Re: lastUpdate nil value  [SOLVED]
jannnfe wrote: Wednesday 10 October 2018 11:07 @dannybloe sorry but what do you mean with just Check the lastUpdate attribute?
You can use my example
