RFXCOM cannot be used? stays in boot load mode? [Solved]
Posted: Tuesday 02 October 2018 22:39
by BigAlbert
Version: 4.9700
Platform: Raspberry Pi
Plugin/Hardware: RFXCCOM RFXtrx433XL
Description:
I am new at the Domoticz and have the Z-Wave Plus stuff installed without any issue.
But I just bought a RFXCOM RFXtrx433XL so I can control my KAKU devices.
When the RFXCOM is inserted into the USB port of the Pi, it is recognized as ttyUSB1.
I can add the hardware in Domoticz:
			RFXCOM - RFXtrx433 USB 433.92MHz
7	RFXCOM	Yes   Transceiver				/dev/ttyUSB1	Disabled
			Version: 27 Set Mode
But when I try to update the firmware I get an error before it starts the updating:
(In the Get Bootloader version part)
Problem updating firmware
RFXCOM: bootloader reset..
I notice that the RFXCOM has a red led burning, it does not go out, which indicates that it is in Boot load mode (what ever that may be :?: )
It does this all the time, from the moment it is inserted to the USB port until it is removed from the USB port.
Can anyone tell me what I can do to fix this? Or is it a DOA RFXCOM?
I tried connecting it to a Windows 10 laptop. In this case the red led is on the entire time as well.
Using the RFXManager I can 'see' the device, but thats it.
The RFXFlash tool doesn't see the device, so I cannot update the firmware from here as well.
TIA,
Albert
Re: RFXCOM cannot be used? stays in boot load mode? Please help!
Posted: Tuesday 02 October 2018 23:06
by b_weijenberg
I suppose the RFXtrx was operating and the update was not correct finished or the wrong firmware was selected.
Please contact support rfxcom.com for the procedure how to recover the RFXtrx.
Posted: Wednesday 03 October 2018 18:23
by BigAlbert
Thanks to the guys at RFXCOM everything now works as expected.
The problem was that I flashed the RFXtrx433E firmware into the FRX433trxXL.
If you do this you cannot flash the correct firmware into it.
After some hardware instructions provided by RFXCOM I could reset the device and could flash the correct firmware using my Windows laptop.
Thanks for the great support Bert!
Re: RFXCOM cannot be used? stays in boot load mode? [Solved]
Posted: Wednesday 28 November 2018 13:03
by schoe024
can you share the instructions from rfxcom?
Posted: Wednesday 28 November 2018 13:41
by b_weijenberg
See chapter 19 in the RFXtrx User Guide how to recover from a wrong or interrupted firmware flash.
