Python Plugin: Buienalarm (NL)
Posted: Tuesday 02 October 2018 21:02
by Xorfor
This Domoticz plugin gets the expected percipitation at your location from https://www.buienalarm.nl/. Other weather hardware/plugins only show the current situation. This plugin shows the rain expectations for the coming 2 hours.
You can use the Alert device to trigger actions, like closing windows, etc.
Plugin can be found @ https://github.com/Xorfor/Domoticz-Buienalarm-Plugin
Look at the README.md for more information.
I have still the following issues:
1. It seems that the api is also working for some countries. I didn't have time to do some more investigation. Therefore this plugin can only be used in the Netherlands and is also in the Dutch language.
2. I am using the Rain device from Domoticz, but also expects the total rainfall, which I can not measure/calculate. Any suggestions.
3. The Domoticz Alert device has 5 levels. I didn't find a better definition for these levels.
Re: Python Plugin: Buienalarm (NL)
Posted: Tuesday 13 November 2018 15:21
by Zoekm
Hello Xorfor, looks nice and something I can use, but I am unable to install the plugin. What I did is copy the plugin.py to the Domoticz plugin directory and set the permission for execution and restarted the RPi (with raspbian-stretch and Domoticz v 4.9700). There is no buienalarm plugin listed on the hardware page to add. Is there something else I have to do to use your plugin?
Thanks,
Zoek
Posted: Tuesday 13 November 2018 16:54
by EdwinK
Make a new directory WITHIN the plugins, and copy plugin.py there
Posted: Tuesday 13 November 2018 16:58
by Zoekm
Hello EdwinK, Thanks for suggestion, but already done that, so must be something else. Also the log does not give any errors.
Posted: Monday 10 June 2019 15:23
by mvroosmalen
Just tested the python plugin and when as described the plugin is placed in a folder in the plugin folder with (755) is appears after restart of domoticz in a few minutes in the hardware as buienalarm. On activation three new devices are created and every 5min these are updated depending on the buienalarm status.
Good work
Mark :D
Posted: Thursday 13 June 2019 14:20
by Krijn20345
I just installed the plugin into /home/pi/domoticz/plugins/buienalarm/plugin.py. But it doesn't appear in my Hardware. Any suggestions?
Krijn
Posted: Thursday 13 June 2019 16:36
by mvroosmalen
Did you change rights to 755 (execute) and restart domoticz?
Mark
Posted: Thursday 23 July 2020 14:41
by mojojojo490
is it possible to make a graph, like the app from Buienalarm does, that you can see for the next 2 hours, when and how much rain is comming?
Posted: Thursday 23 July 2020 18:45
by FireWizard
Hi, @mojojojo490
Do you mean, something like this?
Screenshot_Buienradar leadtime.png (124.62 KiB) Viewed 2890 times
You can use the native Buienradar "hardware", instead of the Python Plug-in.
