Python Plugin: Buienalarm (NL)
Xorfor
Post by Xorfor »
This Domoticz plugin gets the expected percipitation at your location from https://www.buienalarm.nl/. Other weather hardware/plugins only show the current situation. This plugin shows the rain expectations for the coming 2 hours.
You can use the Alert device to trigger actions, like closing windows, etc.
Plugin can be found @ https://github.com/Xorfor/Domoticz-Buienalarm-Plugin
Look at the README.md for more information.
I have still the following issues:
1. It seems that the api is also working for some countries. I didn't have time to do some more investigation. Therefore this plugin can only be used in the Netherlands and is also in the Dutch language.
2. I am using the Rain device from Domoticz, but also expects the total rainfall, which I can not measure/calculate. Any suggestions.
3. The Domoticz Alert device has 5 levels. I didn't find a better definition for these levels.
Zoekm
Re: Python Plugin: Buienalarm (NL)
Post by Zoekm »
Hello Xorfor, looks nice and something I can use, but I am unable to install the plugin. What I did is copy the plugin.py to the Domoticz plugin directory and set the permission for execution and restarted the RPi (with raspbian-stretch and Domoticz v 4.9700). There is no buienalarm plugin listed on the hardware page to add. Is there something else I have to do to use your plugin?
Thanks,
Zoek
EdwinK
Post by EdwinK »
Make a new directory WITHIN the plugins, and copy plugin.py there
Zoekm
Post by Zoekm »
Hello EdwinK, Thanks for suggestion, but already done that, so must be something else. Also the log does not give any errors.
mvroosmalen
Post by mvroosmalen »
Just tested the python plugin and when as described the plugin is placed in a folder in the plugin folder with (755) is appears after restart of domoticz in a few minutes in the hardware as buienalarm. On activation three new devices are created and every 5min these are updated depending on the buienalarm status.
Good work
Mark :D
Krijn20345
Domoticz version: 4.10717
Post by Krijn20345 »
I just installed the plugin into /home/pi/domoticz/plugins/buienalarm/plugin.py. But it doesn't appear in my Hardware. Any suggestions?
Krijn
mvroosmalen
Did you change rights to 755 (execute) and restart domoticz?
Mark
mojojojo490
Post by mojojojo490 »
is it possible to make a graph, like the app from Buienalarm does, that you can see for the next 2 hours, when and how much rain is comming?
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
FireWizard
Post by FireWizard »
Hi, @mojojojo490
Do you mean, something like this?
Screenshot_Buienradar leadtime.png (124.62 KiB) Viewed 3001 times
You can use the native Buienradar "hardware", instead of the Python Plug-in.
