LUA Setpoint temperature to Temperature conversion
Posted: Monday 01 October 2018 22:09
by Bart1992
I'm new to Domoticz, and also LUA. What i'm trying is overlaying multiple temperature (sensors) data in a single graph, including the setpoint temp of my Toon thermostat.
I tried building a (what should be) really easy script including the dummy sensor described in multiple topics. I tried to follow the Weatherunderground temperature scraping example, and modified it slightly in which I thought it should work.... however it doens't.
Can somebody please advice me/looking at this script? As can be seen in the attachment it is printing the input ( Room Setpoint --> sWeathertemp ), however it does not update the dummy temp sensor Setpoint ( idx 18 ).
Looking at the script it's also repeating once triggered, how can I stop it after 1 cycle?
( For me it would be easier if this would have been possible in blockly )
  local sensorwu = 'Room Setpoint' --sensor from wunderground
local idx = 1 --idx of your virtual temp sensor of wunderground
if devicechanged[sensorwu] then
	sWeatherTemp = otherdevices_svalues[sensorwu]:match("([^;]+)")
	sWeatherTemp = tonumber(sWeatherTemp)
	commandArray['UpdateDevice'] = idx .. '|18|' .. tostring(sWeatherTemp)
	print(sWeatherTemp)
	print(sens_temp)
Re: LUA Setpoint temperature to Temperature conversion
Posted: Tuesday 02 October 2018 9:09
by waaren
Bart1992 wrote: Monday 01 October 2018 22:09 ...What i'm trying is overlaying multiple temperature (sensors) data in a single graph, including the setpoint temp of my Toon thermostat.
The code is probably saved as a "Device" or "All" triggered Lua script. In that case it is triggered on every device change in the system and every minute.
In this case it makes more sense to save it as a Time triggered script.
    local sensorwu                          = 'Room Setpoint'    -- Toon device
    local temperatureFromSetpointDeviceIDX  = 1                 -- idx of your virtual temp sensor that will receive setpoint from sensorwu
    local sensorwuTemperature, sensorwuSetpoint, sensorwuMode = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)") -- get temp, setpoint and mode from svalues
    commandArray['UpdateDevice'] = temperatureFromSetpointDeviceIDX .. '|0|' .. sensorwuSetpoint                             -- update virtual device
	-- print("Setpoint of " .. sensorwu .. " is: " .. sensorwuSetpoint)                         -- for debug purposes only (print to log)
Posted: Tuesday 02 October 2018 11:29
by waaren
The previous Lua script was based on my testing on an Evo home temperature + setPoint device.
For a Toon setpoint the script is even more simple
    local sensorwuSetpoint = otherdevices_svalues[sensorwu]     -- get setpoint
Posted: Tuesday 02 October 2018 18:04
by Bart1992
Thanks! Your last small script did the trick, seems really easy when you know the syntax :) !
