Hello all,
RFXCOM supports blinds up to 16 at the moment.
The latest Domoticz stable version only shows blinds up to 13
Recently Bert from RFXCOM added support for Blinds 16 Zemismart, which I like to use.
https://nl.aliexpress.com/item/32809752 ... sstype=600
How can this be included in the pulldown menu domoticz?
Regards,
Martin
Missing RFXCOM supported blinds in Domoticz
Martin
- Domoticz version: stable
- blinds domoticz.JPG (37.12 KiB) Viewed 1061 times
Martin
Re: Missing RFXCOM supported blinds in Domoticz
List of supported blinds in RFXCOM
- blinds rfxcom.JPG (36.12 KiB) Viewed 1031 times
melgi
Martin,
If you try a similar solution as described in this post viewtopic.php?f=44&t=24626 and this post viewtopic.php?f=44&t=24622&p=190270#p190207, I think you might be able to do this. Just be sure you have an RFXcom firmware that can detect Blinds T16.
Martin
Melgi,
Thanks for thinking with me. Unfortunatly RFXCom only supports transmit in case of BlindsT16. So learning from the remote is not an option.
It is working with the RFXmanager program. So firmware support of RFXCom is not an issue.
If I look at the Domoticz code I see the file main/RFXNames.cpp that contains;
{ pTypeBlinds, sTypeBlindsT0, "RollerTrol/Hasta" },
{ pTypeBlinds, sTypeBlindsT1, "Hasta old" },
{ pTypeBlinds, sTypeBlindsT2, "A-OK RF01" },
{ pTypeBlinds, sTypeBlindsT3, "A-OK AC114" },
{ pTypeBlinds, sTypeBlindsT4, "RAEX" },
{ pTypeBlinds, sTypeBlindsT5, "Media Mount" },
{ pTypeBlinds, sTypeBlindsT6, "DC106" },
{ pTypeBlinds, sTypeBlindsT7, "Forest" },
{ pTypeBlinds, sTypeBlindsT8, "Chamberlain" },
{ pTypeBlinds, sTypeBlindsT9, "Sunpery" },
{ pTypeBlinds, sTypeBlindsT10, "Dolat DLM-1" },
{ pTypeBlinds, sTypeBlindsT11, "ASP" },
{ pTypeBlinds, sTypeBlindsT12, "Confexx" },
{ pTypeBlinds, sTypeBlindsT13, "Screenline" },
{ pTypeBlinds, sTypeBlindsT14, "Hualite" },
But how to go forward is above my head
