blinds control with percentage: arduino's relays+espeasy
megamarco83
Post by megamarco83 »
hi i have:
1) 2ch arduino relay
1) nodemcu with espeasy
3) domoticz last revision on raspberry pi
now i want to connect my blind to domoticz. i have 2ch relay:
1ch to UP blinds and 1ch to DOWN the blinds
i punt on espeasy:
gpio12 relay ch n°1 idx=26 that i would like to go UP
gpio15 relay ch n°2 idx=23 that i would like to go DOWN
i create dummy swithc on domoticz, i select simple switch as dummy, then go to switch page in domoticz, click on modify in switch icon and i choose from the internal page of switch "venetian blinds EU"
now i have to enter: action for switch on and action for switch off, but now stars my problems:
1) how i can menage STOP ?
2) the command that i know are:
http://192.168.0.151/control?cmd=GPIO,12,1
that activate relay ch1 to go UP
http://192.168.0.151/control?cmd=GPIO,12,0
that disactivate relay ch1
http://192.168.0.151/control?cmd=GPIO,15,1
that activate relay ch2 to go DOWN
http://192.168.0.151/control?cmd=GPIO,15,0
that disactivate relay ch2
but i have only two space to write in domoticz:
firts space: action for switch on
second space: action for switch off
how i can manage?
if i put on activate: http://192.168.0.151/control?cmd=GPIO,12,1
and in disactivate: http://192.168.0.151/control?cmd=GPIO,15,1
if i pres open blinds, and after two seconds close blinds, i will have active relay ch1 and relay ch2 and i could fire the motor's blind !?!?
what's the correct way to have relay ch1 to go UP relay ch2 to go down, a stop function, and a way that prevent to have switch ON relay ch1 and relay ch2?
thanks
megamarco83
Re: blinds control with percentage: arduino's relays+espeasy
some updating on my progress
now i'm able with EspEasy (using rules) to:
- use wall switch: - short press UP -> relay UP switched on for 1sec
- short press DOWN -> relay DOWN switched on for 1sec
- long press UP (more than 4sec) -> relay UP switched on for 46sec
- long press DOWN (more than 4sec) -> relay DOWN switched on for 46sec
- domoticz blind switch recognize the status of my blind if use wall switch (UP/open or DOWN/close), but i do not recognize the position of the blind (percentage)
i have in mind something but i do not know how to implement:
now with domoticz i should track the amount of sec that are passed since i press the switch, and a script convert the seconds in a percentage.
for example, starting from all close -> i longress UP (relay start to UP with a time of 46sec) -> after 15sec i want to stop my blind i press DOWN shortpress on the wall switch and the blind stop in that position that i choose -> script in domoticz should have counting this 15sec passed and give to domoticz that result: (15sec / 46sec ) * 100= 36% and show on the blind with percentage open 36%
if i use a shortpress wall switch -> i will activate the relay for 1sec -> send to domoticz the value 1sec -> domoticz calcolate (1sec / 46 sec) * 100 = 2% open
if i use again a shorpress from wall swith -> domoticz activate the relay for 1sec -> domoticz calcolate (1sec / 46 sec) * 100 = 2% open + 2% of previous position = 4%open
how i can implement that?
DarkG
Domoticz version: 4.10076
Post by DarkG »
You need a mapping function and a timer to write the position into a user variable. For me it was to complicated.
I did something in Blocky with Selector ans User Variables. But of course I need only 3 Positions for my blinds. Open, close and half open.
And I have no Wall switch. But via ESPEasy and Rules you can send Commands for Selector to Domoticz.
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
