Python Plugin: Psutil Motherboard Sensors
febalci
Post by febalci »
Using Ubuntu, I couldn't get any reliable information from Domoticz Native 'Motherboard Sensors' plugin. Especially the empty space for HDD was always giving wrong information. So I wrote this plugin for my own needs and decided to give up on native 'Motherboard Sensors'.
Installation:
Please install the 'psutil' Python module first:
sudo pip3 install psutil
When you first enable this Plugin It provides:
  • CPU Usage Percentage
  • Memory (Virtual) Memory Usage
  • All mounted HDD Usage Percentages
And, if supported by your platform:
  • Sensor Temperatures (Celcius)
  • Fan Speeds (RPM)
  • Battery Left Percentage
You can find this plugin in https://github.com/febalci/DomoticzPsutil
dextm80
Domoticz version: 4.10159
Re: Python Plugin: Psutil Motherboard Sensors
Post by dextm80 »
Hi! Nice work! I've this issue:
2018-11-11 23:44:43.723 Error: (PsUtil) 'onHeartbeat' failed 'KeyError'.
2018-11-11 23:44:43.723 Error: (PsUtil) ----> Line 247 in '/home/luigi/domoticz/plugins/psutil/plugin.py', function onHeartbeat
2018-11-11 23:44:43.723 Error: (PsUtil) ----> Line 159 in '/home/luigi/domoticz/plugins/psutil/plugin.py', function onHeartbeat
do you known what's the matter?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
febalci
Post by febalci »
dextm80 wrote: Sunday 11 November 2018 23:46 Hi! Nice work! I've this issue:
It turns out the snap devices on ubuntu is causing a problem on both native domoticz motherboard sensors and this psutil motherboard sensors. Please check: https://github.com/domoticz/domoticz/issues/2822
On Ubuntu, the loop devices created with snap are changing the df -h output order. So the number of disk devices and their order changes everytime, which in native motherboard sensors gives the wrong result, or in psutil motherboard sensors, an error. As a quick fix i deleted all my snap devices; but since snap is a thing on ubuntu now, i need to correct this situation in my plugin someday.
Can you please check 'df -h' and look if any loop devices or canonical snap devices exist?
dextm80
Post by dextm80 »
febalci wrote: Monday 12 November 2018 10:24
this is my df -h report:
File system     Dim. Usati Dispon. Uso% Montato su
udev            3,7G     0    3,7G   0% /dev
tmpfs           764M  3,0M    761M   1% /run
/dev/sda2        82G   46G     32G  59% /
tmpfs           3,8G  124M    3,7G   4% /dev/shm
tmpfs           5,0M  4,0K    5,0M   1% /run/lock
tmpfs           3,8G     0    3,8G   0% /sys/fs/cgroup
/dev/sdc1       916G   16G    855G   2% /media/sdd1
/dev/sdb1       1,8T  1,2T    572G  68% /media/sdb1
/dev/sdd1       459G  401G     35G  93% /media/sdc1
/dev/sda1       511M  6,2M    505M   2% /boot/efi
/dev/sde1       250G   19M    250G   1% /media/sdf1
/dev/sdf1       932G  298G    635G  32% /media/sde1
tmpfs           764M   40K    764M   1% /run/user/1000
1x Fibaro Wall Plug
Philips Hue Bridge
febalci
Post by febalci »
dextm80 wrote: Monday 12 November 2018 17:24 this is my df -h report:
I guess i fixed the keyError now. Also added 'Network Mount Drives' if you want to follow up the mounted network drives disk usage; that is selectable on the plugin profile page. Could you try the new version 0.3 on the github?
dextm80
Post by dextm80 »
febalci wrote: Friday 16 November 2018 10:21
Yes, but i get this error:
 2018-11-18 01:00:13.400 Error: (Psutil) failed to load 'plugin.py', Python Path used was '/home/luigi/domoticz/plugins/PSUtil/:/usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload'.
2018-11-18 01:00:13.400 Error: (PSUtil Motherboard Sensor) Module Import failed, exception: 'ModuleNotFoundError'
2018-11-18 01:00:13.400 Error: (PSUtil Motherboard Sensor) Module Import failed: ' Name: psutil'
2018-11-18 01:00:13.400 Error: (PSUtil Motherboard Sensor) Error Line details not available.
1x Fibaro Wall Plug
Philips Hue Bridge
febalci
Post by febalci »
dextm80 wrote: Sunday 18 November 2018 1:01 Yes, but i get this error:
You have to install psutil python module in order for this plugin to work. You can do it with:
dextm80
Post by dextm80 »
febalci wrote: Sunday 18 November 2018 12:00
it seems ok now, thank you
1x Fibaro Wall Plug
Philips Hue Bridge
