i'm going to install a door sersor detection and my idea would have a wall tablet camera to take a pitcure and send mail if door opened.Anyone has coded this feature with script or using apk solutions on domoticz?
Thanks in advance.
use tablet camera as motion detection
underscore4
ben53252642
Re: use tablet camera as motion detection
underscore4, I'm not aware of any pre-built solutions however I'd suggest looking at an Android App called Tasker.
I used it successfully to turn Android tablet screens on / off when a motion sensor is activated, it can do many different things.
underscore4
Nice, thanks a lot.
I will test it. would be also visible in Domoticz with any way?
ben53252642
Use a second App (for Tasker) called Autoremote to trigger it remotely from Domoticz using a script
I was also able to send text from Domoticz to the tablet and have it speak it out loud.
You will need to do some research and a small amount of coding (mostly copy and paste) to achieve what you want but it is do-able.
https://www.youtube.com/watch?v=ro_dFnrEAUY
Here is a sample bash script I use to send messages to Autoremote
As I said what you want to do is achievable but this goes into moderate to advanced scripting level.
#!/bin/bash
message=$(echo "message to send goes here" | sed 's/ /%20/g')
curl "https://autoremotejoaomgcd.appspot.com/sendmessage?key=THEAUTOREMOTEKEYGOESHERE&message=${message}"
markk
I do something similar very easily.underscore4 wrote: Saturday 15 September 2018 11:10 Hi,
Thanks in advance.
Use this method viewtopic.php?t=17659#p135550 to turn your tablet camera into an IP camera and add it to Domoticz then use the Domoticz notification function or a simple blockly to send you a snapshot when the door sensor is triggered.
