Digital LED Strip and RF Controller
Posted: Sunday 11 May 2014 22:15
by Shyam
HI All,
I've just purchased a rfxtrx 433 and got it working with Domoticz, raspberry pi and lightwaverf.
The question I have is, I've got this led strip set up:
http://www.ebay.co.uk/itm/5M-5050-Dream ... 20dffd219b Is there a way I can use Domoticz to send signals to the rf controller via the 433?
Shyam
Re: Digital LED Strip and RF Controller
Posted: Monday 12 May 2014 8:43
by b_weijenberg
This controller is and will not be supported.
Check chapter 2.2 in the RFXtrx User Guide for the list of devices supported by the RFXtrx.
Posted: Monday 12 May 2014 9:25
by krizzz
A wifi led controller will do the trick, but this has nothing to do with 433mhz and the RFXcom!
Posted: Monday 12 May 2014 10:15
by Shyam
Thanks for you reply guys.
@krizzz - can you recommend a WIFI controller?
Posted: Monday 12 May 2014 10:28
by krizzz
I Just bought one and i am expecting it the 20th of may to come in, so you have to wait for the feedback
Posted: Monday 12 May 2014 10:29
by Shyam
awesome! I'll wait for your review.
Posted: Monday 12 May 2014 11:58
by b_weijenberg
Shyam: search this forum also for Applamp
Posted: Monday 12 May 2014 18:25
by Shyam
Thanks for suggestion.
The thing is that my current controller gives 133 effects..do we know if the AppLamp gives the same functionality?
Posted: Monday 12 May 2014 19:42
by Ritmeester
For as I know for now: The Applamp (Mi Light) in Domoticz cannot play any programmed effects on your lamp or LED Strips. Just specified colors by Scenes
Posted: Monday 12 May 2014 22:38
by Shyam
Ritmeester wrote:For as I know for now: The Applamp (Mi Light) in Domoticz cannot play any programmed effects on your lamp or LED Strips. Just specified colors by Scenes
Thought so... Will continue my investigating..
Posted: Saturday 07 June 2014 16:47
by safi78
Hi Shyam,
About the effects: Applamp RGBW has 4 zones, 255 colors + White and 19 dim-levels.
For programming them I use this:
http://www.domoticz.com/forum/viewtopic.php?f=17&t=1526 which is very easy to use in scripting, so you can basically control the zones, colours and dim-levels exactly the way you want.
Posted: Tuesday 05 May 2015 17:11
by Shyam
bumping up a old thread. I'm still looking for a way to control my addressable led strip
Posted: Tuesday 05 May 2015 17:14
by Derik
Shyam wrote:bumping up a old thread. I'm still looking for a way to control my addressable led strip
I did it simple with a Switch...[ Action, a very cheap one ]
Once you get the good colors, most of the time is it swich on/off.
Posted: Tuesday 05 May 2015 17:16
by Shyam
Derik wrote:Shyam wrote:bumping up a old thread. I'm still looking for a way to control my addressable led strip
Thanks Derik,
Could you give me more details..not sure I quite understand
Posted: Tuesday 05 May 2015 17:31
by Derik
I just buy a simple led strip in China.
5 m voor €5.
A 12v power adapter, perhaps you have 1, or look @ the recycle place from your hometown, or buy a cheap in China.
Buy some connectors in China, for the strpi and to the poweradapter.
Buy a cheap 433Mhz[ Whe you have the E version] or a other cheap supported device, or a expensive Zwave switch.
Make the strip @ the length you want....
Make sure you make the adapter on the good way on your ledstrip!! + and - goed! [ or rgb - ]
Learn the switch
and you got a remote ledstrip...
Posted: Tuesday 05 May 2015 18:09
by RayAmsterdam
Applamp/Milight works like a charm. You can control the basics with Domoticz. The effect you can control with the Applamp/Milight app. You can also program your own effects.
Posted: Wednesday 06 May 2015 10:12
by Shyam
Thanks for the replies.
The only thing is that my LED strips is not RGB, its this one:
http://www.ebay.co.uk/itm/32leds-M-Blac ... 3ce9d97cd0
Posted: Wednesday 06 May 2015 10:21
by Derik
Not?
Your link says rgb?
When it is not RGB my option will work great.
Posted: Wednesday 06 May 2015 10:55
by Shyam
This is the exact one i have:
Its RGB such that you can select RGB colours, but if you look at the connections, its not RGB, its Data and Clock. And from the link you can see that it can have up to 133 effects.
Posted: Wednesday 16 March 2016 12:57
by hayman
hello hello,
i'm new here
is there still no thing about the LED (lp8603) and the controller ,i have other controller
http://www.aliexpress.com/item/WF300-Wi ... 3ea7e9fe8b
will this work ....?
thanks again
