Digital LED Strip and RF Controller
Shyam
Post by Shyam »
HI All,
I've just purchased a rfxtrx 433 and got it working with Domoticz, raspberry pi and lightwaverf.
The question I have is, I've got this led strip set up: http://www.ebay.co.uk/itm/5M-5050-Dream ... 20dffd219b Is there a way I can use Domoticz to send signals to the rf controller via the 433?
Shyam
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
Accenta Gen4 Security System Integration
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Blog: http://www.shyambhundia.com
b_weijenberg
Re: Digital LED Strip and RF Controller
Post by b_weijenberg »
This controller is and will not be supported.
Check chapter 2.2 in the RFXtrx User Guide for the list of devices supported by the RFXtrx.
RFX-433, RFX-433EMC, RFX-868
krizzz
Post by krizzz »
A wifi led controller will do the trick, but this has nothing to do with 433mhz and the RFXcom!
Shyam
Post by Shyam »
Thanks for you reply guys.
@krizzz - can you recommend a WIFI controller?
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
krizzz
Post by krizzz »
I Just bought one and i am expecting it the 20th of may to come in, so you have to wait for the feedback :)
Shyam
Post by Shyam »
awesome! I'll wait for your review.
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
b_weijenberg
Shyam: search this forum also for Applamp
Shyam
Post by Shyam »
Thanks for suggestion.
The thing is that my current controller gives 133 effects..do we know if the AppLamp gives the same functionality?
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Ritmeester
Post by Ritmeester »
For as I know for now: The Applamp (Mi Light) in Domoticz cannot play any programmed effects on your lamp or LED Strips. Just specified colors by Scenes
Shyam
Post by Shyam »
Ritmeester wrote:For as I know for now: The Applamp (Mi Light) in Domoticz cannot play any programmed effects on your lamp or LED Strips. Just specified colors by Scenes
Thought so... Will continue my investigating..
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
safi78
Domoticz version: LastBeta
Post by safi78 »
Hi Shyam,
About the effects: Applamp RGBW has 4 zones, 255 colors + White and 19 dim-levels.
For programming them I use this: http://www.domoticz.com/forum/viewtopic.php?f=17&t=1526 which is very easy to use in scripting, so you can basically control the zones, colours and dim-levels exactly the way you want.
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Shyam
Post by Shyam »
bumping up a old thread. I'm still looking for a way to control my addressable led strip
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Derik
Post by Derik »
Shyam wrote:bumping up a old thread. I'm still looking for a way to control my addressable led strip
I did it simple with a Switch...[ Action, a very cheap one ]
Once you get the good colors, most of the time is it swich on/off.
Shyam
Post by Shyam »
Thanks Derik,
Could you give me more details..not sure I quite understand :?
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Derik
Post by Derik »
I just buy a simple led strip in China.
5 m voor €5.
A 12v power adapter, perhaps you have 1, or look @ the recycle place from your hometown, or buy a cheap in China.
Buy some connectors in China, for the strpi and to the poweradapter.
Buy a cheap 433Mhz[ Whe you have the E version] or a other cheap supported device, or a expensive Zwave switch.
Make the strip @ the length you want....
Make sure you make the adapter on the good way on your ledstrip!! + and - goed! [ or rgb - ]
Learn the switch
and you got a remote ledstrip...:-)
RayAmsterdam
Post by RayAmsterdam »
Applamp/Milight works like a charm. You can control the basics with Domoticz. The effect you can control with the Applamp/Milight app. You can also program your own effects.
Shyam
Post by Shyam »
Thanks for the replies.
The only thing is that my LED strips is not RGB, its this one:http://www.ebay.co.uk/itm/32leds-M-Blac ... 3ce9d97cd0
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Derik
Post by Derik »
Shyam wrote:Thanks for the replies.
Not?
Your link says rgb?
When it is not RGB my option will work great.
Shyam
Post by Shyam »
This is the exact one i have: http://www.ebay.co.uk/itm/5M-5050-Dream ... 20dffd219b
Its RGB such that you can select RGB colours, but if you look at the connections, its not RGB, its Data and Clock. And from the link you can see that it can have up to 133 effects.
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
hayman
Domoticz version: 3.8153
Post by hayman »
hello hello,
i'm new here
is there still no thing about the LED (lp8603) and the controller ,i have other controller http://www.aliexpress.com/item/WF300-Wi ... 3ea7e9fe8b
will this work ....?
thanks again
