Devicechanged script not triggered
Piacco
Post by Piacco »
Hello, i have a Itho ventilation system with a remote control en Itho ESP.
When i press a button on my remote control i want to update a selector switch in Domoticz.
To update the selector switch i use a LUA script, only this script won't run, in my devices tab i see that when i press a button on the remote control that Itho_actuele_stand is updated, what do i wrong?
if (devicechanged['Itho_actuele_stand'] == '1.00' and otherdevices['Ihto Ventilatie'] ~= 'Low') then
commandArray['UpdateDevice'] = '290|10|10'
elseif (devicechanged['Itho_actuele_stand'] == '2.00' and otherdevices['Ihto Ventilatie'] ~= 'Medium') then
commandArray['UpdateDevice'] = '290|20|20'
elseif (devicechanged['Itho_actuele_stand'] == '3.00' and otherdevices['Ihto Ventilatie'] ~= 'High') then
commandArray['UpdateDevice'] = '290|30|30'
elseif (devicechanged['Itho_actuele_stand'] == '13.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer1') then
commandArray['UpdateDevice'] = '290|40|40'
elseif (devicechanged['Itho_actuele_stand'] == '23.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer2') then
commandArray['UpdateDevice'] = '290|50|50'
elseif (devicechanged['Itho_actuele_stand'] == '33.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer3') then
commandArray['UpdateDevice'] = '290|60|60'
SweetPants
Re: Devicechanged script not triggered
Post by SweetPants »
Try to add some print statements so you know if/where your script fails.
Piacco
Post by Piacco »
I have changed the script into:
		devices = {
if (device['Itho_actuele_stand'] == '1.00' and otherdevices['Ihto Ventilatie'] ~= 'Low') then
        domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
    elseif (device['Itho_actuele_stand'] == '2.00' and otherdevices['Ihto Ventilatie'] ~= 'Medium') then
    elseif (device['Itho_actuele_stand'] == '3.00' and otherdevices['Ihto Ventilatie'] ~= 'High') then
    elseif (device['Itho_actuele_stand'] == '13.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer1') then
    elseif (device['Itho_actuele_stand'] == '23.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer2') then
    elseif (device['Itho_actuele_stand'] == '33.00' and otherdevices['Ihto Ventilatie'] ~= 'Timer3') then
Now i can see that the script is triggerd, but the selector switch won't update :( i have (checked the idx of the selector switch)
HansieNL
Post by HansieNL »
Your nValues and sValues are the same. Have you tried to change the nValue to 1.
commandArray['UpdateDevice'] = '290|1|10'
Blah blah blah
