Why would LUA be really slow? Topic is solved
jefft
Domoticz version: 2023.1
Post by jefft »
I have a really simple LUA script to toggle the state of a light when a switch is pushed, but when I trigger the event, there's a huge delay (8~10 seconds typically!) before the target device changes state. I'm using LUA to avoid the silliness with Blockly and its fall-through "elseif" clauses, but when I tried one half of this logic ("if switch on/off and light off then light on") in Blockly, the target light changed state instantly.
Why would doing this through LUA be so slow? I'm really puzzled. Anyone have any ideas of what I can check / try, please?
-- hall second switch channel to toggle state of landing lights (catch both state changes in hall switch as it's a toggle)
if (devicechanged['Hall switch landing'] == 'On' or devicechanged['Hall switch landing'] == 'Off') then
  print ("Hall-switch-landing LUA event fired");
  if (otherdevices['Landing lights'] == 'Off') then
    commandArray['Landing lights']='On'
    commandArray['Landing lights']='Off'
System info:
Version: 4.9701
Build Hash: b47a877f
Compile Date: 2018-06-23 14:27:56
dzVents Version: 2.4.6
Python Version: 3.6.5 (default, Apr 1 2018, 05:46:30) [GCC 7.3.0]
Domoticz is running on an Ubuntu 18.04 server VM with 2vCPU, 2GB RAM, on a VMWare ESXi host.
Z-wave is Aeotec z-stick Gen 5.
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
jvdz
Domoticz version: 4.107
Re: Why would LUA be really slow?
Post by jvdz »
Does the log entry also take that long or just the switch of the light?
What is shown for that in the domoticz log?
Jos
jefft
Post by jefft »
Good thought, Jos.
A log entry shows up immediately for the switch action and right after it (<0.5s.) for "Domoticz is sending a command", then the light switches some time after that, quite variable - just had it take 2s and 10s on two consecutive tries. On and off seem to be either quicker or slower together. The light's control module is z-wave, so it could be that the z-wave network was having a hard time earlier, perhaps, and has now settled a bit. I'll force a network heal to make sure.
I also spotted a surprising error in the log after the last test:
2018-09-07 15:51:48.529  Status: LUA: Hall-switch-landing LUA event fired
2018-09-07 15:51:48.529  (Z-Wave (Aeotec Z-Stick Gen5)) Light/Switch (Hall switch landing)
2018-09-07 15:51:48.530  Status: EventSystem: Script event triggered: Hall switch2 landing lights
2018-09-07 15:51:48.559  OpenZWave: Domoticz has send a Switch command! NodeID: 23 (0x17)
2018-09-07 15:51:48.560  (Z-Wave (Aeotec Z-Stick Gen5)) Light/Switch (Landing lights)
2018-09-07 15:51:55.015  (Z-Wave (Aeotec Z-Stick Gen5)) Usage (Unknown)
2018-09-07 15:51:55.015  (Z-Wave (Aeotec Z-Stick Gen5)) General/kWh (kWh Meter)
[b]2018-09-07 15:52:00.331  Error: EventSystem: in Hall switch2 landing lights: [string "--..."]:29: attempt to index global 'devicechanged' (a nil value)[/b]
(line 29 is actually the first "if" in the code; I cut off the header comments when I posted it); I've stripped out a few irrelevant log lines caused by other, non-z-wave devices reporting in.
So, it looks like the command is sent (@48.559), received by the light and acknowledged with a status report (@48.560) all within milliseconds, then 7 seconds later the light reports a change in power usage (@55.015) which seems to cause the event to be run again, creating the error (@00.331). That empty devicechanged array is strange... why would any event code be called if no device has changed?
The light didn't actually switch on until around the same time as the power report was sent. I guess that part has to be some sort of z-wave or module configuration problem, given that the light module clearly acknowledged the command very quickly.
Any ideas on the error?
jefft
Post by jefft »
Oh, update...
I left the log scrolling in real time while I was configuring some other devices and I just spotted the same error coming up repeatedly - the event is definitely being triggered by the power meter reports coming in from z-wave devices (not just this device, I think, looks like any device), but then an empty 'devicechanged' array is being passed to the event code and crashing it.
Sounds like something that needs to be coded around by checking what caused the event to run, or possibly a bug in that there ought to be something in the array to say that the power meter changed...?
I guess for this event, I can check the dimensions of the array and quit if it's empty. Time to brush up on my LUA coding!
That raises a different question, though - how would one use a change in power usage to trigger an event, if that were the intention?
heggink
Domoticz version: 12451
Post by heggink »
Why not try dzvents?
DASHTICZ 🙃
P1 meter & solar panel
jefft
Post by jefft »
heggink wrote: Friday 07 September 2018 18:21 Why not try dzvents?
Another language to learn (I get the basics of LUA having used Vera for a few years before seeing the light) and it looks more complex. Is it likely not to have the issues with empty device arrays etc?
jvdz
Post by jvdz »
Let me guess: You have coded this in the internal editor and haven't made it a "Device" script?
Check the dropdown for All and change that to Devices. ;)
Jos
jefft
Post by jefft »
jvdz wrote: Friday 07 September 2018 18:47 Let me guess: You have coded this in the internal editor and haven't made it a "Device" script?
Jos
Ah! :oops: Can I remove the "if devicechanged == nil" check now, then?
heggink
Post by heggink »
Dzvents is just lua but then specifically adapted for domoticz. For one, had you used that instead of standard lua then this issue would not have occurred at all. I switched completely from blockly to dzvents. It's really simple to adopt.
DASHTICZ 🙃
jvdz
Post by jvdz »
jefft wrote: Friday 07 September 2018 18:58 Can I remove the "if devicechanged == nil" check now, then?
Sure as that table is always provided with a Device Event, but won't be there for the other types of events.
Jos
Users browsing this forum: hjzwiers and 1 guest
