mqtt update value if changed
emme
Domoticz version: latest
Post by emme »
Ciao,
it might be possible to add a boolean option in the mqtt string for domoticz/in topic where to update the vale ONLY if the actual value is different (like already done in dzvents with the .checkFirst() function)?
something like:
{"command": "switchlight", "idx": 0, "switchcmd": "Off", "checkfirst": true }
if omitted the "checkfirst": true (or setted to false) the value will be overwritten without control
this would be useful in keeping track of devices and variables state based on a time value (if a variable/switch is not updated for a certain amount of time do stuff)
thank
ciao
M
"We always done this way"
riko
Re: mqtt update value if changed
Post by riko »
I was exactly looking for this functionally. Is this already possible, or is there a workaround?
Domoticz version: 2025.1
I think there is an option in Domoticz menu setup - settings -tab Log history that do just that: "Only add newly received values to the log"
riko
Post by riko »
If I understand the manual correctly this is aimed at showing and keeping the data in the log of a sensor. Not about the update of the sensor itself?
Give it a try and you will see if it works.
In what manual did you read this?
riko
Post by riko »
This is where I found it, it is really a description about how the log is kept: https://www.domoticz.com/wiki/Applicati ... og_History
But you might be right, i'll give it a try later!
