Create a device
DanM
Create a device
Post by DanM »
If there any way to check if a device exists and create it if not?
Best,
Dan
SweetPants
Re: Create a device
Post by SweetPants »
First you need a list with all devices in the system, used or not.
http://<ip>:<port>/json.htm?type=devices&filter=all&order=Name
This returns a JSON with all devices, you can now test if the device exists and create a new one if not
Re: Create a device
DanM wrote: Tuesday 28 August 2018 11:27 Hi,
Best,
Dan
To check if a device exist and is set to active:
local deviceName = "your device name"
local myDevice          = domoticz.devices(deviceName)
if myDevice then
 domoticz.log("device " .. myDevice.name .. " exist and is active")
 domoticz.log("device " .. deviceName .. " does not exist or is set inactive")
to create a device you will need to call domoticz via an API https://www.domoticz.com/wiki/Domoticz_ ... _commands
This can be done using the openURL command in dzVents
