I've searched this forum and the internet but found no solution that applies to my dilemma. I've had to set the timeout setting on my openzwave device to force domoticz to poll the zstick every 5 minutes. I'm not sure what I'm doing wrong, but I know it's working because my home energy monitor sends kilowatt usage when zwave is restarted but doesn't continuously poll. I have polling enabled on the energy monitors. I set the timeout on the zstick to 5 minutes so that it would poll at least that often by resetting the device. I'm sure I must need to change a setting somewhere because it does the same thing on 2 different computers (or is this how it is supposed to work?). BTW, I have 0 experience with ZWave standard. I understand the basics but don't know how it should be interacting with the energy monitors I have.
//Edit...I just wanted to add the log file to see if anyone can tell me if this looks normal or not.
2018-08-26 15:12:32.821 Status: OpenZWave: All Nodes queried
2018-08-26 15:12:36.791 Status: OpenZWave: Heal Network command initiated...
2018-08-26 15:16:31.875 Error: Nest: Error getting current state!
2018-08-26 15:17:01.889 Error: Nest: Error login!
2018-08-26 15:17:31.902 Error: Nest: Error login!
2018-08-26 15:18:00.595 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:18:01.730 Status: OpenZWave: Closed
2018-08-26 15:18:01.595 Error: Restarting: ZStick
2018-08-26 15:18:01.916 Error: Nest: Error login!
2018-08-26 15:18:03.242 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:18:03.243 Status: OpenZWave: Starting...
2018-08-26 15:18:03.244 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:18:03.369 Status: OpenZWave: Driver Ready
2018-08-26 15:18:03.370 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:18:03.370 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:18:03.371 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:18:03.371 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:18:31.930 Error: Nest: Error login!
2018-08-26 15:19:01.944 Error: Nest: Error login!
2018-08-26 15:19:16.436 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:19:31.957 Error: Nest: Error login!
2018-08-26 15:19:38.410 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:19:39.584 Status: OpenZWave: All Nodes queried
2018-08-26 15:20:01.971 Error: Nest: Error login!
2018-08-26 15:20:41.988 Error: Nest: Error login!
2018-08-26 15:21:21.996 Error: Nest: Error login!
2018-08-26 15:22:01.999 Error: Nest: Error login!
2018-08-26 15:22:42.015 Error: Nest: Error login!
2018-08-26 15:23:22.022 Error: Nest: Error login!
2018-08-26 15:24:02.027 Error: Nest: Error login!
2018-08-26 15:24:42.035 Error: Nest: Error login!
2018-08-26 15:25:00.280 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:25:01.769 Status: OpenZWave: Closed
2018-08-26 15:25:01.280 Error: Restarting: ZStick
2018-08-26 15:25:03.279 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:25:03.280 Status: OpenZWave: Starting...
2018-08-26 15:25:03.280 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:25:03.407 Status: OpenZWave: Driver Ready
2018-08-26 15:25:03.407 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:25:03.407 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:25:03.408 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:25:03.408 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:25:22.039 Error: Nest: Error login!
2018-08-26 15:25:25.557 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:25:43.459 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:26:02.048 Error: Nest: Error login!
2018-08-26 15:26:42.052 Error: Nest: Error login!
2018-08-26 15:26:54.907 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:26:56.081 Status: OpenZWave: All Nodes queried
2018-08-26 15:27:22.068 Error: Nest: Error login!
2018-08-26 15:32:00.032 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:32:01.306 Status: OpenZWave: Closed
2018-08-26 15:32:01.032 Error: Restarting: ZStick
2018-08-26 15:32:02.817 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:32:02.818 Status: OpenZWave: Starting...
2018-08-26 15:32:02.819 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:32:02.945 Status: OpenZWave: Driver Ready
2018-08-26 15:32:02.945 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:32:02.946 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:32:02.946 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:32:02.947 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:32:55.373 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:33:05.374 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:33:17.804 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:33:49.157 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:33:50.989 Status: OpenZWave: All Nodes queried
2018-08-26 15:39:00.584 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:39:01.844 Status: OpenZWave: Closed
2018-08-26 15:39:01.584 Error: Restarting: ZStick
2018-08-26 15:39:03.351 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:39:03.352 Status: OpenZWave: Starting...
2018-08-26 15:39:03.352 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:39:03.475 Status: OpenZWave: Driver Ready
2018-08-26 15:39:03.476 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:39:03.476 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:39:03.476 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:39:03.477 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:39:35.537 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:40:41.025 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:40:59.334 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:41:00.508 Status: OpenZWave: All Nodes queried
2018-08-26 15:44:27.163 Error: Nest: Error getting current state!
2018-08-26 15:46:30.323 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:46:31.380 Status: OpenZWave: Closed
2018-08-26 15:46:31.323 Error: Restarting: ZStick
2018-08-26 15:46:32.891 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:46:32.892 Status: OpenZWave: Starting...
2018-08-26 15:46:32.892 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:46:33.017 Status: OpenZWave: Driver Ready
2018-08-26 15:46:33.017 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:46:33.018 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:46:33.018 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:46:33.019 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:48:11.829 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:48:13.003 Status: OpenZWave: All Nodes queried
2018-08-26 15:51:19.698 Status: EventSystem: reset all device statuses...
2018-08-26 15:53:30.638 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 15:53:31.918 Status: OpenZWave: Closed
2018-08-26 15:53:31.638 Error: Restarting: ZStick
2018-08-26 15:53:33.429 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 15:53:33.430 Status: OpenZWave: Starting...
2018-08-26 15:53:33.431 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 15:53:33.557 Status: OpenZWave: Driver Ready
2018-08-26 15:53:33.557 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 15:53:33.557 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 15:53:33.558 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:53:33.558 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 15:54:32.056 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 15:54:57.534 Status: OpenZWave: Awake Nodes queried
2018-08-26 15:54:58.708 Status: OpenZWave: All Nodes queried
2018-08-26 15:55:03.823 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:55:03.843 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:55:41.575 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:55:41.598 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:56:12.138 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:56:12.160 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:56:43.868 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:56:43.887 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:57:16.206 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:57:16.227 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:57:47.851 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:57:47.872 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:58:19.056 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:58:19.077 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:58:49.751 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:58:49.772 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:59:20.281 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:59:20.302 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 15:59:51.966 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 15:59:51.989 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:00:22.873 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:00:22.892 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:00:30.437 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 16:00:31.456 Status: OpenZWave: Closed
2018-08-26 16:00:31.437 Error: Restarting: ZStick
2018-08-26 16:00:32.968 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 16:00:32.969 Status: OpenZWave: Starting...
2018-08-26 16:00:32.970 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 16:00:33.095 Status: OpenZWave: Driver Ready
2018-08-26 16:00:33.095 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 16:00:33.096 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 16:00:33.096 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 16:00:33.096 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 16:00:36.675 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 1
2018-08-26 16:00:36.675 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-08-26 16:00:37.859 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Unknown, Instance: 1
2018-08-26 16:00:37.860 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-08-26 16:00:51.588 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 16:00:53.362 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:00:53.382 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:00:59.826 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 2
2018-08-26 16:01:11.873 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2018-08-26 16:01:13.056 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 2
2018-08-26 16:01:23.982 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:01:24.004 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:01:27.171 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2018-08-26 16:01:46.440 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:01:46.461 (ZStick) Usage (Unknown)
2018-08-26 16:01:46.484 (ZStick) Usage (Power Meter)
2018-08-26 16:01:47.624 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:01:47.644 (ZStick) Usage (Unknown)
2018-08-26 16:01:47.665 (ZStick) Usage (Power Meter)
2018-08-26 16:01:48.811 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2018-08-26 16:01:48.833 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:01:50.014 (ZStick) Usage (Unknown)
2018-08-26 16:01:50.039 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:01:51.181 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 2
2018-08-26 16:01:51.202 (ZStick) General/kWh (kWh Meter)
2018-08-26 16:01:52.384 (ZStick) Usage (Unknown)
2018-08-26 16:01:52.406 (ZStick) General/kWh (kWh Meter)
2018-08-26 16:01:54.776 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:01:54.797 (ZStick) Usage (Unknown)
2018-08-26 16:01:54.818 (ZStick) Usage (Power Meter)
2018-08-26 16:01:56.032 (ZStick) Usage (Unknown)
2018-08-26 16:01:56.052 (ZStick) Usage (Power Meter)
2018-08-26 16:01:56.197 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:01:56.216 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:01:57.196 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:01:57.215 (ZStick) Usage (Unknown)
2018-08-26 16:01:57.234 (ZStick) Usage (Power Meter)
2018-08-26 16:01:58.478 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:01:58.500 (ZStick) Usage (Unknown)
2018-08-26 16:01:58.522 (ZStick) Usage (Power Meter)
2018-08-26 16:01:59.663 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2018-08-26 16:01:59.687 (ZStick) General/kWh (Sq D1 kWh Meter)
2018-08-26 16:02:02.175 (ZStick) General/kWh (Sq D1 kWh Meter)
2018-08-26 16:02:03.375 (ZStick) Usage (Unknown)
2018-08-26 16:02:03.393 (ZStick) General/kWh (Sq D1 kWh Meter)
2018-08-26 16:02:05.776 Status: OpenZWave: Awake Nodes queried
2018-08-26 16:02:06.950 Status: OpenZWave: All Nodes queried
2018-08-26 16:02:09.338 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:02:10.514 (ZStick) Usage (Unknown)
2018-08-26 16:02:10.535 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:02:28.397 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:02:28.431 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:02:59.016 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:02:59.036 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:03:29.821 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:03:29.842 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:04:00.977 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:04:00.996 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:04:31.614 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:04:31.635 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:05:01.993 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:05:02.015 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:05:32.337 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:05:32.357 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:06:02.819 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:06:02.843 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:06:33.238 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:06:33.259 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:07:03.698 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:07:03.724 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:07:30.726 Error: ZStick hardware (2) nothing received for more than 5 Minutes!....
2018-08-26 16:07:31.997 Status: OpenZWave: Closed
2018-08-26 16:07:31.726 Error: Restarting: ZStick
2018-08-26 16:07:33.508 Status: OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2018-08-26 16:07:33.509 Status: OpenZWave: Starting...
2018-08-26 16:07:33.510 Status: OpenZWave: Version: 1.4.2893.g22d04077.dirty
2018-08-26 16:07:33.636 Status: OpenZWave: Driver Ready
2018-08-26 16:07:33.636 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 1 (0x01)
2018-08-26 16:07:33.637 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 3 (0x03)
2018-08-26 16:07:33.637 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 16:07:33.638 Status: OpenZWave: New Node added. HomeID: 25506756, NodeID: 5 (0x05)
2018-08-26 16:07:34.364 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:07:34.386 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:07:42.316 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 1
2018-08-26 16:07:42.316 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-08-26 16:07:58.290 Status: OpenZWave: Received timeout notification from HomeID: 25506756, NodeID: 4 (0x04)
2018-08-26 16:08:00.926 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 2
2018-08-26 16:08:00.926 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 3
2018-08-26 16:08:02.444 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2018-08-26 16:08:03.627 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 2
2018-08-26 16:08:04.810 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 3
2018-08-26 16:08:05.077 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:08:05.100 (Central AC) Temp + Humidity (Home Dining Room TempHum)
2018-08-26 16:08:18.939 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:08:18.960 (ZStick) Usage (Unknown)
2018-08-26 16:08:18.979 (ZStick) Usage (Power Meter)
2018-08-26 16:08:20.123 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:08:20.144 (ZStick) Usage (Unknown)
2018-08-26 16:08:20.165 (ZStick) Usage (Power Meter)
2018-08-26 16:08:21.307 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2018-08-26 16:08:21.329 (ZStick) Usage (Unknown)
2018-08-26 16:08:21.353 (ZStick) Usage (Power Meter)
2018-08-26 16:08:22.491 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2018-08-26 16:08:22.513 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:08:23.701 (ZStick) Usage (Unknown)
2018-08-26 16:08:23.721 (ZStick) General/kWh (GE1 kWh Meter)
2018-08-26 16:08:24.863 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 2
2018-08-26 16:08:24.883 (ZStick) General/kWh (kWh Meter)
2018-08-26 16:08:26.072 (ZStick) Usage (Unknown)
2018-08-26 16:08:26.091 (ZStick) General/kWh (kWh Meter)
2018-08-26 16:08:27.237 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 3
2018-08-26 16:08:27.258 (ZStick) General/kWh (GE2 kWh Meter)
2018-08-26 16:08:28.448 (ZStick) Usage (Unknown)
2018-08-26 16:08:28.468 (ZStick) General/kWh (GE2 kWh Meter)
2018-08-26 16:08:31.209 Status: OpenZWave: All Nodes queried
2018-08-26 16:08:36.666 (Central AC) Thermostat (Home Dining Room Setpoint)
2018-08-26 16:08:36.688 (Central AC) Temp + Humidity (Home Dining Room TempHum)
ZStick S2 only polls once during startup then times out...Hopefully someone can tell me if this is normal or not.
