mqtt : "stop" value implemented for blinds
Posted: Sunday 26 August 2018 7:40
by mrelfire
Is it possible to have the "Stop" value implemented to allow blinds to be manipulated with mqtt ?
example :
2018-08-25 10:11:19.678 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":149,"switchcmd":"Stop"}
today we have this error
2018-08-25 10:11:19.678 Error: MQTT: Invalid data received!
so we have the same command either in http or mqtt ?
thanks in advance
Re: mqtt : "stop" value implemented for blinds
Posted: Sunday 02 September 2018 10:31
by mrelfire
I have proposed" if it is possibl"e to had the "stop" value , but perhaps people can have some other suggestions ?
@developpers => is it complicated ? feasible ?
thans in advance
Posted: Sunday 02 September 2018 12:30
by ben53252642
You could achieve stop using levels via MQTT (although I agree with your proposal).
viewtopic.php?f=68&t=23607&start=20#p188171
Look at the Node-Red example for the Xiaomi button (import it).
There may be levels for the blind switch you can simply send, eg an to turn a simple on off switch on would usually be level 255 and to turn it off would usually be level 0 (can vary).
Is there a level number for the stop?
Posted: Sunday 02 September 2018 19:12
by mrelfire
unfortunately no.
"We" need a "stop" implementation
Posted: Sunday 02 September 2018 19:50
by ben53252642
mrelfire wrote: Sunday 02 September 2018 19:12
unfortunately no.
If you really need it, you can indeed do it via levels.
Create a selector switch then map it using Lua to stop the blind, control the selector switch via MQTT.
Not the easiest way I know but it would work.
Posted: Monday 03 September 2018 8:20
by mrelfire
I have 15 blinds. followinf your suggestion I will have to create 15 others switches for levels , wich I map to my first 15 ids => a nightmare
now I have as script which swith for open on mqtt calls, and for off on https calls
not clean but in waiting as you sayed
Posted: Wednesday 10 October 2018 13:33
by mrelfire
perhaps it is a bug, no clues => should I move it to the bug forum ?
any suggestions ?
Posted: Wednesday 10 October 2018 13:36
by jvdz
Was my answer in this thread not sufficient?
viewtopic.php?f=28&t=24600
It doesn't look like a bug but more a feature request.... which means somebody needs to have the urge to code it.
Jos
Posted: Wednesday 10 October 2018 17:25
by mrelfire
unfortunately "Toggle" or "Set Level" doesn't stop a blind up or down
so perhaps you are right, "we" need some code
Posted: Sunday 09 December 2018 8:13
by mrelfire
Is it a bug ? => do I have to do a request on github please ?
Posted: Sunday 09 December 2018 8:25
by waaren
mrelfire wrote: Sunday 09 December 2018 8:13
I have setup something like what you need with the use of one domoticz uservariable and a dzVents script. Would that help you ?
Posted: Sunday 09 December 2018 9:04
by mrelfire
would you mind to give me the link so I can test it please ?
Posted: Sunday 09 December 2018 13:47
by waaren
mrelfire wrote: Sunday 09 December 2018 9:04
This should do it.
--[[ this scripts handles commmunication from MQTT to domoticz uservar
mosquitto_pub -r -t domoticz/in -m '{"command":"setuservariable","idx":61,"value":"1099"}'
change 61 to the idx of your (type string) domoticz uservariable
change 1099 to the idx of your blind
this dzVents script will pickup the variable and stop the blind
local blindStopperVariableIDX = 61
on = { variables = { blindStopperVariableIDX }},
logging = { level = domoticz.LOG_DEBUG,
marker = "MQTT Blind" },
execute = function(dz, item, info )
_G.logMarker = info.scriptName -- sets the logmarker for dz.log
local function logWrite(str,level)
dz.log(str,level or dz.LOG_DEBUG)
blind = dz.devices(tonumber(item.value))
blind.stop()
logWrite("device " .. blind.name .. " stopped")
Posted: Saturday 02 February 2019 10:47
by mrelfire
I am confused, how you trigger this script when you do a mqtt action, this is quite strange and confusing to make a generic to bypass a code limitation.
I manage to see your point but not a clue to implement it and make it generic
