mqtt : "stop" value implemented for blinds
mrelfire
Post by mrelfire »
Is it possible to have the "Stop" value implemented to allow blinds to be manipulated with mqtt ?
example :
2018-08-25 10:11:19.678 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx":149,"switchcmd":"Stop"}
today we have this error
2018-08-25 10:11:19.678 Error: MQTT: Invalid data received!
so we have the same command either in http or mqtt ?
thanks in advance
mrelfire
Re: mqtt : "stop" value implemented for blinds
Post by mrelfire »
I have proposed" if it is possibl"e to had the "stop" value , but perhaps people can have some other suggestions ?
@developpers => is it complicated ? feasible ?
thans in advance ;)
ben53252642
Post by ben53252642 »
You could achieve stop using levels via MQTT (although I agree with your proposal).
viewtopic.php?f=68&t=23607&start=20#p188171
Look at the Node-Red example for the Xiaomi button (import it).
There may be levels for the blind switch you can simply send, eg an to turn a simple on off switch on would usually be level 255 and to turn it off would usually be level 0 (can vary).
Is there a level number for the stop?
mrelfire
Post by mrelfire »
unfortunately no.
"We" need a "stop" implementation ;)
ben53252642
mrelfire wrote: Sunday 02 September 2018 19:12 unfortunately no.
If you really need it, you can indeed do it via levels.
Create a selector switch then map it using Lua to stop the blind, control the selector switch via MQTT.
Not the easiest way I know but it would work.
mrelfire
Post by mrelfire »
I have 15 blinds. followinf your suggestion I will have to create 15 others switches for levels , wich I map to my first 15 ids => a nightmare
now I have as script which swith for open on mqtt calls, and for off on https calls
not clean but in waiting as you sayed
mrelfire
Post by mrelfire »
perhaps it is a bug, no clues => should I move it to the bug forum ?
any suggestions ?
jvdz
Domoticz version: 4.107
Post by jvdz »
Was my answer in this thread not sufficient?
viewtopic.php?f=28&t=24600
It doesn't look like a bug but more a feature request.... which means somebody needs to have the urge to code it.
Jos
mrelfire
Post by mrelfire »
unfortunately "Toggle" or "Set Level" doesn't stop a blind up or down ;)
so perhaps you are right, "we" need some code :)
mrelfire
Post by mrelfire »
Is it a bug ? => do I have to do a request on github please ?
mrelfire wrote: Sunday 09 December 2018 8:13 Is it a bug ? => do I have to do a request on github please ?
I have setup something like what you need with the use of one domoticz uservariable and a dzVents script. Would that help you ?
mrelfire
Post by mrelfire »
would you mind to give me the link so I can test it please ?
mrelfire wrote: Sunday 09 December 2018 9:04 would you mind to give me the link so I can test it please ?
This should do it.
--[[    this scripts handles commmunication from MQTT to domoticz uservar
        mosquitto_pub -r -t domoticz/in -m '{"command":"setuservariable","idx":61,"value":"1099"}'
        change 61 to the idx of your (type string) domoticz uservariable
        change 1099 to the idx of your blind
        this dzVents script will pickup the variable and stop the blind
local blindStopperVariableIDX = 61
            on      =   {   variables       =   { blindStopperVariableIDX }},
            logging =   {   level           =   domoticz.LOG_DEBUG,
                            marker          =   "MQTT Blind"    },
    execute = function(dz, item, info )
        _G.logMarker             = info.scriptName                  -- sets the logmarker for dz.log
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
        blind = dz.devices(tonumber(item.value))
        blind.stop()
        logWrite("device " .. blind.name .. " stopped")
mrelfire
Post by mrelfire »
I am confused, how you trigger this script when you do a mqtt action, this is quite strange and confusing to make a generic to bypass a code limitation.
I manage to see your point but not a clue to implement it and make it generic
