Question from a NOOB...
I had to re-install Domoticz on my PI 2B.
Before, everything worked well and I could use Putty.
Now, Domoticz works again, I can access it on my W10 laptop and my Androids Phone, but I cannot use Putty anymore (Access denied message)
Any ideas for me?
Thx!
problem with Putty
mark.sellwood
Re: problem with Putty
SSH is disabled by default so putty wont connect as you are seeing.
To enable SSH you have 2 options: -
1) To enable SSH you need to place an empty file named 'SSH' on the SD-card to enable SSH on boot.
2) Connect a keyboard & monitor, log in & run sudo raspi-config, in one of the menus you can enable SSH
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Johndomo
Great, thank you! I.m going to try this tomorrow!
freijn
- Domoticz version: Stable
goto the Gui or the commandline on your HDMI output
type
sudo raspi-config
goto interfaces and check if ssh is enabled
type
sudo raspi-config
Johndomo
Yes, it works! Thx again guys!
