trigger Google Assistant with domoticz via "text query" : Google home is a bridge for domoticz
Alexa, Google Home and Siri
fpatou
Post by fpatou »
Currently it is rather "simple" (and free) to use the voice to trigger domoticz scenes via:
Google Assistant => IFTT => domoticz.
But is it possible to do the opposite via google assistant text query ? :
domoticz => Google Assistant=>Google Home to trigger a scene
I explain myself ,I try to drive the scenes of the broadlink rm mini 3 via domoticz without any local installation of RM bridge.
I was able to "plug" those scenes with google home and use them with the voice via a google assistant whit google home mini: it works ! meaning Google home plays the role of a bridge for broadlink.
If we go further we can imagine that google home could even be a "global bridge" for all that is compatible with google home.(Philips HUE,Samsung SmartThings etc...etc....)
But how to call google Assistant requests from domoticz?
After multiple search I managed to run a python script with query_text parameter on domoticz calling google assistant!
So I tried to trigger a scene of Broadlink rm mini 3 and .... bingo! it works
tested with domoticz PI3 and Windows with an on/off button calling python script : no problems !
to do it :
follow the step by step from google here "Embed the Google Assistant":
https://developers.google.com/assistant ... ce/python/
Then test with this script:
https://github.com/googlesamples/assist ... xtinput.py
Script that I have updated to add parameter like 'activate light in living room'.
I can now trigger all the google home devices without any local software bridge installation for domoticz : google home is The bridge !
Meaning as soon as google home have devices compatible...this is compatible with domoticz !!!!!!
Meaning google home via google assistant become a secured bridge hosted in the cloud for domoticz!
of course without network....you will have to walk to the button :D
If we go again further....just imagine : query to google assistant give answer in the script, that can be parsed ....
if you are interested to get more detail let me know.
find files and other details (in french) for pi installation at the end of that post :
https://easydomoticz.com/forum/viewtopi ... 814#p57814
Thank you
Pixal
Domoticz version: 4.10199
Re: trigger Google Assistant with domoticz via "text query" : Google home is a bridge for domoticz
Post by Pixal »
I don't understand why you have no responses to this but I'm interested and will try this out sometime. I'm up to another (above my paygrade) challenge.
I want Google Home to initiate the conversation and talk to me instead of the other way around. For example, I've got tons of situations where I would like Google Home to talk to me. When the Alarm goes off i want Google to say "get out of here, an alarm has been triggered" or, "say the secret passcode within 30 seconds to stop the alarm".
But I also would like Google to talk to me and ask if it's ok to turn off the lights and heater. I've got a few motion detectors in the living room so I had set them to switch off lights and heat when there's no motion for one hour. But sometimes I'm sitting very silently for hours and everything suddenly shuts down around me, it would be good to get a heads up from Google, "turning off lights in 10 minutes".
Am I the only one who wants to explore these kind of things? I have played around with Home Assistant once and noticed I could send texts to Google Home and she would say them but haven't found it in Domoticz yet.
fpatou
Post by fpatou »
Pixal wrote: Monday 24 December 2018 13:28 Am I the only one who wants to explore these kind of things? I have played around with Home Assistant once and noticed I could send texts to Google Home and she would say them but haven't found it in Domoticz yet.
Hello...
With the google assistant installed in Domoticz as mention in this thread, you can send "text query" to google home from domoticz...
The google home "broadcast" feature is THE answer (https://github.com/endoplasmic/google-a ... /issues/52), if this would
be possible of course all 3 tier framework (stream2chromecast for instance) would be useless but for time being i did not succeed to make it work, but for sure i will dig it cause as you, i need to have voice acknowledge for some actions.
Today the only "simple" option to make Goole home talking from assistant text query from domoticz is tu use IFTTT :
domoticz =>Google Assistant=>IFTTT=>Google Assistant.
puls8
Post by puls8 »
fpatou wrote: Wednesday 26 December 2018 11:06 Today the only "simple" option to make Goole home talking from assistant text query from domoticz is tu use IFTTT :
Hmm, how do you setup the first step? (domoticz =>Google Assistant)
Dnpwwo
Post by Dnpwwo »
@fpatou and @Pixal,
Getting you home to "say something" from Domoticz when an event happens is possible today via https://github.com/dnpwwo/Domoticz-Goog ... /README.md.
This is still version 1 because it does not pause existing media and restart it afterwards but it is a start.
maximaxi
Domoticz version: 4.10717
Post by maximaxi »
It is possible to have some examples to know how to use the routine
Thank you
fpatou
Post by fpatou »
Hello once the script is saved use something like this :
ex: command ON un a switch :
script:///home/pi/env/bin/python3 /home/pi/script/gass5.pyw --device-model-id <your model id> --device-id <your device id> --query_txt "turn on the tv"
Then if your tv is compliant or if there is a Chromecast on it...domoticz trigger the event for instance if you come back home. Can be the same to switch off the lights on a dedicated schedule...
maximaxi
Post by maximaxi »
I ask if possible a step by step guide for how to use it within domoticz Thank you
freijn
Domoticz version: Stable
Post by freijn »
Interesting !
maximaxi
Post by maximaxi »
Someone would be kind enough to give me a hand
for example to send a message when I press an iterrutore
and how to set up the script
Thank youImage
to do tests I could write it directly here
if instead I have to call an example script in python it is possible to have an example
thank you
arma_esiea
Post by arma_esiea »
This is already functional
rezzalex
Post by rezzalex »
Hello @fpatou,
Very interesting, even more with the recent change of business model of IFTTT...
My Goal would be to pass a querry to Google Home that can "Arm" my wireless cam (already working with voice command, thanks to the manufacturer and Google), triggered from the DZ home presence that I have set-up.
I am using DZ in a container and :
- don't want to mess-up with what is working smoothly (and don't succeed in creating a python virtual env)
- don't want to reinstall everything (SDK) at every container update.
Also, I tried to use an existing Projet in Google Console but impossible to find the way to Register a device here, so I have created a new project in google console...
is it possible to separate the Script part (python, SDK, Script, token...) in a container and make DZ still able to call it ?
