Hello all,
Today we got a Aluprof DC305A (Remote) installed with our Sunscreen. It uses RTS on 433Mhz (CR2430). Any idea how to control it with Domoticz? I tried RFY and RFY-2 but it doesnt respond to that when I click the P2 (Pair) button on the remote.
Update: heb deze uiteindelijk via RFXManager moeten koppelen met het confirm commando via Blinds T6. Daarna werkt het in Domoticz ook.
Aluprof DC305A
b_weijenberg
- Target OS: -
Re: Aluprof DC305A
Is this remote received in the latest RFXmngr and the latest Pro1 firmware?
RFX-433, RFX-433EMC, RFX-868
mvroosmalen
Re: Aluprof DC305A
Yes it is I've tested it (Pro1) yesterday and the remote code is captured via the RFXManager, but the firmware is not supported in Domoticz. No clue why....As mentioned by others you can transmit via the learning steps.
for example: https://ehoco.nl/elektrisch-rolgordijn- ... n-domoticz
If someone is able to integrate the Pro1 firmware in Domoticz, let us know
Mark
Update:
Something went wrong using the flash update program on my PC, however after using the update option in Domoticz (setup>Hardware>RFxCom, set mode>Upgrade Firmware) I successfully upgraded the RFxCom with the Pro1 firmware and can add the DC305A via the learning option in Domoticz. Now Domoticz detects open or close (stop) commando's of the remote and can be used to send commands to open/close/stop. Perfect!!
Thanks to the makers!!! Good job.
Mark
Mark
Update:
Mark
b_weijenberg
- Target OS: -
Re: Aluprof DC305A
Is the DC305A remote received in Domoticz if you have the BlindsT1 protocol enabled?
Or else manually create a BlindsT6 device on the Switches tab. (Use RFXmngr to receive the ID of the remote)
See also chapter 10 in the RFXtrx User Guide.
