Help Example, months of the year
Posted: Sunday 19 August 2018 10:05
by Derik
Dear all.
I try to understand dzvents.. [ hard to get for me ]
I try to make a script wjere every month of the year is acting with Domoticz.
12 dummys that switch on the month of the year.
Looks for me a simple start to begin.Only i get unfortunately not 1 month to switch to the good month..
Is there perhaps someone that can give me some basic code from where i can start?
Re: Help Example, months of the year
Posted: Monday 20 August 2018 0:20
by waaren
Derik wrote: Sunday 19 August 2018 10:05
I am not sure I completely understand what you try to achieve but based on my assumption that you have created a virtual switch for every month and only want the switch with the name of the current month to be switched to On, I have put together the script below.
Please let me know if my assumption is incorrect or if you do not completely understand the script.
-- setMonthswitch.lua
on = { timer = { "at 00:01" }}, -- the script will run every night at 00:01
logging = { level = domoticz.LOG_DEBUG, -- this sets the loglevel. Options are LOG_INFO, LOG_DEBUG, LOG_ERROR or LOG_FORCE
marker = "setMonthswitch" }, -- the marker will ensure you can see where information comes from
execute = function(dz) -- the parm dz (short for domoticz) will ensure all information from domoticz is available in this script
months={ "januari", -- months is here a table (or array) with all month names. The names can be accessed by months[1] .. months[12]
"februari",
"maart",
"april",
"mei",
"juni",
"juli",
"augustus",
"september",
"oktober",
"november",
"december" }
dz.log(months[tonumber(os.date("%m"))],dz.LOG_DEBUG) -- os.date("%m") returns the month-number with a leading zero as a string.
-- tonumber converts this string to a number
for i = 1,#months do -- #months means max. items in the table months (so for loop from 1 to 12)
dz.devices(months[i]).switchOff().checkFirst() -- Switch off all virtual switches labeled with names of the months
-- checkFirst() wil make sure switch will only be done when before state is different
dz.devices(months[tonumber(os.date("%m"))]).switchOn().checkFirst() -- Only current month switch will be set to on (when not already done)
Posted: Monday 20 August 2018 16:22
by bimse
Try with
timer = { 'at 00:01 on 1/*'}, -- Every 1st of the month at 00:01
Posted: Monday 20 August 2018 16:42
by waaren
bimse wrote: Monday 20 August 2018 16:22
Try with
Thanks. It kind of depends what is most important for the user. With your modification the script would run once a month and thus saving CPU cycles
and it would work most of the times but if the system is down for two minutes at that particular moment the switches would show a wrong month for the whole month. With my example it would run once a day and burning CPU (0.026 seconds on my PI-3 system) and the switches could be off for a day if the system is down for two minutes on the first day of the month at 00:01)
So it is up to user environment what is most important. Execute monthly, -daily ( or even hourly ? )
But credits for you to show this alternative
Posted: Monday 20 August 2018 20:00
by Derik
Dear all.
Thanks for this, i see now your reaction, i get no notification from the forum??
So i give it a try .... this evening
you hear from me..
Ps i can change the names for the months in the script to what i want?
En what setting do i need in dz vents.. all time or device?
Edit:
Error:
2018-08-20 20:13:14.485 Status: dzVents: Error (2.4.7): error loading module 'DZ: Maanden' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/DZ: Maanden.lua':
2018-08-20 20:13:14.485 ...moticz/scripts/dzVents/generated_scripts/DZ: Maanden.lua:9: unexpected symbol near '`'
2018-08-20 20:13:14.544 Status: dzVents: Error (2.4.7): error loading module 'DZ: Maanden' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/DZ: Maanden.lua':
2018-08-20 20:13:14.544 ...moticz/scripts/dzVents/generated_scripts/DZ: Maanden.lua:9: unexpected symbol near '`'
Posted: Monday 20 August 2018 20:21
by Derik
The error found .. grrrr
Only now I have:
- ScreenShot255.png (11.75 KiB) Viewed 2199 times
And:
- ScreenShot256.png (89.17 KiB) Viewed 2199 times
Only not working..
Posted: Monday 20 August 2018 20:26
by waaren
Derik wrote: Monday 20 August 2018 20:00
Dear aall.
you hear from me..
Edit:
Error:
Oops.. overlooked one quote.. I removed it in the script so please try again.
You can change the names to your liking but do not remove- or add one and they must be the same as your dummy devices.
For dzVents it does not matter what type you use in the internal event editor the type is determined in the on = section
Posted: Monday 20 August 2018 20:31
by waaren
Derik wrote: Monday 20 August 2018 20:21
Only not working..
Did you define all (virtual) month switches ?
Do you see something in the log ?
Posted: Monday 20 August 2018 20:35
by Derik
mm i did try only 1 month
No thing in the log..
i make first all the months...
then
I be back
Posted: Monday 20 August 2018 20:39
by waaren
Derik wrote: Monday 20 August 2018 20:35
then
I be back
And please load the example again. Found one other typo
Posted: Monday 20 August 2018 20:45
by Derik
Did all the months:
- ScreenShot257.png (87.55 KiB) Viewed 2187 times
and:
- ScreenShot258.png (92.25 KiB) Viewed 2187 times
No thing to see in the log
Posted: Tuesday 21 August 2018 23:32
by waaren
Derik wrote: Monday 20 August 2018 20:45
Can you copy / paste the script again and report your findings ?
At least something should be visible in the logfile.
Posted: Wednesday 22 August 2018 17:51
by Derik
-- setWindChill.lua
on = { timer = { "every 10 minutes" }}, -- the script will run every 10 minutes
-- logging = { level = domoticz.LOG_DEBUG, -- this sets the loglevel. Options are LOG_INFO, LOG_DEBUG, LOG_ERROR or LOG_FORCE
-- marker = "setWindchill" }, -- the marker will ensure you can see where information comes from
----- enter your settings below this line -------------------------------------------------------------------------------
myTemperature = dz.devices("Buiten: Terras") -- Name of your windDevice within quotes or idx without quotes
myWind = dz.devices("D.M.: Buienradar - Wind") -- Name of your temperatureDevice within quotes or idx without quotes
myWindChill = dz.devices("D.M.: Windchill") -- Name of your windchill Device within quotes or idx without quotes
----- enter your settings above this line -------------------------------------------------------------------------------
function windChill(windSpeed, temperature)
if temperature == nil then return -99 -- Should not happen
elseif windSpeed == nil then return -99 -- Should not happen
-- chill temperature cannot be calculated for these conditions
elseif windSpeed < 1.3 or windSpeed > 49 or temperature < -46 or temperature > 17 then return temperature
return dz.utils.round(13.12 + (0.6215 * temperature) - (13.96 * math.pow(windSpeed, 0.16)) + (0.4867 * temperature * math.pow(windSpeed, 0.16)), 1)
myWindChill.updateTemperature(windChill(myWind.speed,myTemperature.temperature))
The output:
- ScreenShot262.png (15.04 KiB) Viewed 2110 times
Log:
17:50:00.810 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:05.897 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:11.600 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:20.599 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:30.325 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:38.978 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-08-22 17:50:47.763 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
That are scripts without any thing?
Perhaps one of these?
Posted: Wednesday 22 August 2018 20:56
by Derik
Proud on myself
THANKS to Jos..
Did change his script, for seazos..
MY first script that is working:
-- script_time maanden.lua
time = os.date("*t")
-- check once a minute for the months to change
if (time.month == 1) then
if otherdevices["D.M.: Januari D"] == 'Off' then
commandArray['D.M.: Januari D'] = 'On'
commandArray['D.M.: Februari D'] = 'Off'
commandArray['D.M.: Maart D'] = 'Off'
commandArray['D.M.: April D'] = 'Off'
commandArray['D.M.: Mei D'] = 'Off'
commandArray['D.M.: Juni D'] = 'Off'
commandArray['D.M.: Juli D'] = 'Off'
commandArray['D.M.: Augustus D'] = 'Off'
commandArray['D.M.: September D'] = 'Off'
commandArray['D.M.: Oktober D'] = 'Off'
commandArray['D.M.: November D'] = 'Off'
commandArray['D.M.: December D'] = 'Off'
elseif (time.month == 2) then
if otherdevices ["D.M.: Februari D"] == 'Off' then
commandArray['D.M.: Januari D'] = 'Off'
commandArray['D.M.: Februari D'] = 'On'
elseif (time.month == 3) then
if otherdevices ["D.M.: Maart D"] == 'Off' then
commandArray['D.M.: Maart D'] = 'On'
elseif (time.month == 4) then
if otherdevices ["D.M.: April D"] == 'Off' then
commandArray['D.M.: April D'] = 'On'
elseif (time.month == 5) then
if otherdevices ["D.M.: Mei D"] == 'Off' then
commandArray['D.M.: Mei D'] = 'On'
elseif (time.month == 6) then
if otherdevices ["D.M.: Juni D"] == 'Off' then
commandArray['D.M.: Juni D'] = 'On'
elseif (time.month == 7) then
if otherdevices ["D.M.: Juli D"] == 'Off' then
commandArray['D.M.: Juli D'] = 'On'
elseif (time.month == 8) then
if otherdevices ["D.M.: Augustus D"] == 'Off' then
commandArray['D.M.: Augustus D'] = 'On'
elseif (time.month == 9) then
if otherdevices ["D.M.: September D"] == 'Off' then
commandArray['D.M.: September D'] = 'On'
elseif (time.month == 10) then
if otherdevices ["D.M.: Oktober D"] == 'Off' then
commandArray['D.M.: Oktober D'] = 'On'
elseif (time.month == 11) then
if otherdevices ["D.M.: November D"] == 'Off' then
commandArray['D.M.: November D'] = 'On'
elseif (time.month == 12) then
if otherdevices ["D.M.: December D"] == 'Off' then
commandArray['D.M.: December D'] = 'On'
print('Er is iets mis in het script van Maanden :)')
