running domoticz->Fatal Python error: drop_gil: GIL is not locked
bassie127
Post by bassie127 »
I compiled domoticz on Arch linux (AUR package https://aur.archlinux.org/packages/domoticz/).
* Building is OK.
* When I start domoticz via: systemctl start domoticz it crashes with "Fatal Python error: drop_gil: GIL is not locked".
* I have searched but cannot find a solution.
All tips appreciated.
Service file:
[Unit]
Description=Domoticz Daemon
After=network.target
[Service]
User=http
Group=http
PermissionsStartOnly=true
ExecStartPre=/usr/bin/install -d -m 0700 -o http -g http /var/run/domoticz
ExecStart=/opt/domoticz/domoticz -www 8090 -pidfile /var/run/domoticz/domoticz.pid
PIDFile=/var/run/domoticz/domoticz.pid
WorkingDirectory=/opt/domoticz
#RestartSec=5
#Restart=on-failure
[Install]
WantedBy=multi-user.target
Log below:
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.517 Status: Domoticz V4.5876 (c)2012-2016 GizMoCuz
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.517 Status: Build Hash: b97777b, Date: 2016-11-09 12:33:42
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.517 Status: Startup Path: /opt/domoticz/
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.612 Status: PluginSystem: Started, Python version '3.7.0'.
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.620 Active notification Subsystems: gcm, http (2/13)
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.621 Status: WebServer(HTTP) started on address: :: with port 8090
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.637 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.637 Error: WebServer(SSL) check privileges for opening ports below 1024
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.637 Status: Proxymanager started.
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.639 Starting shared server on: :::6144
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.639 Status: TCPServer: shared server started...
Aug 18 13:06:44 RPI3 domoticz[20602]: 2018-08-18 13:06:44.640 Status: RxQueue: queue worker started...
Aug 18 13:06:46 RPI3 domoticz[20602]: 2018-08-18 13:06:46.641 Status: EventSystem: reset all events...
Aug 18 13:06:46 RPI3 domoticz[20602]: 2018-08-18 13:06:46.642 Status: EventSystem: reset all device statuses...
Aug 18 13:06:46 RPI3 domoticz[20602]: Fatal Python error: drop_gil: GIL is not locked
Aug 18 13:06:46 RPI3 domoticz[20602]: Current thread 0x71cfd3e0 (most recent call first):
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 81 in _path_stat
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 87 in _path_is_mode_type
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 102 in _path_isdir
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 1447 in path_hook_for_FileFinder
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 1197 in _path_hooks
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 1221 in _path_importer_cache
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 1249 in _get_spec
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap_external>", line 1280 in find_spec
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap>", line 906 in _find_spec
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap>", line 963 in _find_and_load_unlocked
Aug 18 13:06:46 RPI3 domoticz[20602]: File "<frozen importlib._bootstrap>", line 983 in _find_and_load
Aug 18 13:06:46 RPI3 systemd[1]: Started Process Core Dump (PID 20613/UID 0).
bolderbast
Domoticz version: 4.10717
Re: running domoticz->Fatal Python error: drop_gil: GIL is not locked
Post by bolderbast »
did you ever get this resolved? I'm currently experiencing the same issue.
bolderbast
Because the error is python related, I decided to downgrade the 2 python packages that were upgraded just before the issue occurred:
  • python-setuptools (1:40.4.3-1 -> 1:40.2.0-1)
  • python (3.7.0-4 -> 3.6.6-1)
Now I don't get the error anymore.
For me this is an acceptable workaround. I hope a future update of python or domoticz will fix this issue.
loesje
Post by loesje »
I saw some other projects that solved the issue, and they all reference https://vstinner.github.io/python37-gil-change.html. This post also explains why it still works with older versions of Python. (the complete story: https://bugs.python.org/issue20891)
Seems like that Domoticz needs a fix to be able to use the latest Python version. I think that this issue is about the same problem.
Dnpwwo
Post by Dnpwwo »
Are you building beta or stable?
Python 3.7 support was added in beta and tested in Windows a while ago
zynexiz
Domoticz version: 3.8805
Post by zynexiz »
bolderbast wrote: Monday 24 September 2018 14:16 Because the error is python related, I decided to downgrade the 2 python packages that were upgraded just before the issue occurred:
Where did you find the downgrade installation? Culdn't find any in repos for Arch (only AUR). Trying to compile it myself now, but run in to some problem with it (hopefully my fix will work).
-- Mike
bolderbast
zynexiz wrote: Thursday 01 November 2018 20:45
-- Mike
I had the previous version in my pacman cache: /var/cache/pacman/pkg/
Hope you have them too!
