Device "clouds" based on wunderground api
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
I want to created a device that is based on the value weather
Below you can find the reponse of the api an d i want a device that is update with the weather value "geheel bewolkt"
  "response": {
  "version":"0.1",
  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
  "features": {
  "conditions": 1
  ,	"current_observation": {
		"image": {
		"url":"http://icons.wxug.com/graphics/wu2/logo_130x80.png",
		"title":"Weather Underground",
		"link":"http://www.wunderground.com"
		"display_location": {
		"full":"Weerde, Belgium",
		"city":"Weerde",
		"state":"VLG",
		"state_name":"Belgium",
		"country":"BX",
		"country_iso3166":"BE",
		"zip":"00000",
		"magic":"85",
		"wmo":"06448",
		"latitude":"50.970974",
		"longitude":"4.465515",
		"elevation":"9.1"
		"observation_location": {
		"full":"Kleine Brogel, ",
		"city":"Kleine Brogel",
		"state":"",
		"country":"BE",
		"latitude":"50.97",
		"longitude":"4.47",
		"elevation":"26 ft"
		"estimated": {
		"station_id":"IZEMST12",
		"observation_time":"Last Updated on augustus 15, 1:14 PM CEST",
		"observation_time_rfc822":"Wed, 15 Aug 2018 13:14:18 +0200",
		"observation_epoch":"1534331658",
		"local_time_rfc822":"Wed, 15 Aug 2018 13:14:35 +0200",
		"local_epoch":"1534331675",
		"local_tz_short":"CEST",
		"local_tz_long":"Europe/Brussels",
		"local_tz_offset":"+0200",
		"weather":"Geheel bewolkt",
		"temperature_string":"68.4 F (20.2 C)",
		"temp_f":68.4,
		"temp_c":20.2,
		"relative_humidity":"74%",
		"wind_string":"Calm",
		"wind_dir":"WZW",
		"wind_degrees":244,
		"wind_mph":0,
		"wind_gust_mph":0,
		"wind_kph":0,
		"wind_gust_kph":0,
		"pressure_mb":"1020",
		"pressure_in":"30.12",
		"pressure_trend":"0",
		"dewpoint_string":"60 F (15 C)",
		"dewpoint_f":60,
		"dewpoint_c":15,
		"heat_index_string":"NA",
		"heat_index_f":"NA",
		"heat_index_c":"NA",
		"windchill_string":"NA",
		"windchill_f":"NA",
		"windchill_c":"NA",
		"feelslike_string":"68.4 F (20.2 C)",
		"feelslike_f":"68.4",
		"feelslike_c":"20.2",
		"visibility_mi":"6.2",
		"visibility_km":"10.0",
		"solarradiation":"247",
		"UV":"3.0","precip_1hr_string":"0.00 in ( 0 mm)",
		"precip_1hr_in":"0.00",
		"precip_1hr_metric":" 0",
		"precip_today_string":"0.00 in (0 mm)",
		"precip_today_in":"0.00",
		"precip_today_metric":"0",
		"icon":"cloudy",
		"icon_url":"http://icons.wxug.com/i/c/k/cloudy.gif",
		"forecast_url":"http://www.wunderground.com/global/stations/06448.html",
		"history_url":"http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IZEMST12",
		"ob_url":"http://www.wunderground.com/cgi-bin/findweather/getForecast?query=50.970974,4.465515",
		"nowcast":""
Can somenhelp with this?
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Re: Device "clouds" based on wunderground api
Lebo2d9 wrote: Wednesday 15 August 2018 13:18 ...
Can someone help with this?
What is the URL you use to get this ?
Do you want the string "geheel bewolkt" in a text device ?
Lebo2d9
Post by Lebo2d9 »
Hi Waaren,
The URL I use is http://api.wunderground.com/api/myapike ... MST12.json
and Yes i want the result of the weather string in a text device.
Kind regrds
More to come
SweetPants
Post by SweetPants »
The Baro device already contains this information derived from the "icon"
"icon":"cloudy" -> "weather":"Geheel bewolkt"
"icon":"partlycloudy" -> "weather":"Partly Cloudy"
So this text device would be redundant
Lebo2d9
Post by Lebo2d9 »
This is the code I already have in dzVents
	active = true,
		timer = {
			--'at 23:58'
			'every 5 minutes'
	execute = function(domoticz)
        local Date = domoticz.time.year..domoticz.time.month..domoticz.time.day
	    json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
        local key = "code"
        local location = "pws:IZEMST12" --plaatsnaam of personal weather station invoeren
	    local file=assert(io.popen('curl http://api.wunderground.com/api/'..key..'/conditions/q/'..location..'.json'))
	    local raw = file:read('*all')
	    file:close()
	    local deviceinfo = json:decode(raw)
        domoticz.log('raw:'..raw)
And this is the log i have
2018-08-16 19:55:00.189 Status: dzVents: Info: ------ Start internal script: dzVentstestWU:, trigger: every 5 minutes
2018-08-16 19:55:00.662 Status: dzVents: Info: raw:
2018-08-16 19:55:00.662 {
2018-08-16 19:55:00.662 "response": {
2018-08-16 19:55:00.662 "version":"0.1",
2018-08-16 19:55:00.662 "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
2018-08-16 19:55:00.662 "features": {
2018-08-16 19:55:00.662 "conditions": 1
2018-08-16 19:55:00.662 }
2018-08-16 19:55:00.662 ,	"current_observation": {
2018-08-16 19:55:00.662 "image": {
2018-08-16 19:55:00.662 "url":"http://icons.wxug.com/graphics/wu2/logo_130x80.png",
2018-08-16 19:55:00.662 "title":"Weather Underground",
2018-08-16 19:55:00.662 "link":"http://www.wunderground.com"
2018-08-16 19:55:00.662 },
2018-08-16 19:55:00.662 "display_location": {
2018-08-16 19:55:00.662 "full":"Weerde, Belgium",
2018-08-16 19:55:00.662 "city":"Weerde",
2018-08-16 19:55:00.662 "state":"VLG",
2018-08-16 19:55:00.662 "state_name":"Belgium",
2018-08-16 19:55:00.662 "country":"BX",
2018-08-16 19:55:00.662 "country_iso3166":"BE",
2018-08-16 19:55:00.662 "zip":"00000",
2018-08-16 19:55:00.662 "magic":"85",
2018-08-16 19:55:00.662 "wmo":"06448",
2018-08-16 19:55:00.662 "latitude":"50.970974",
2018-08-16 19:55:00.662 "longitude":"4.465515",
2018-08-16 19:55:00.662 "elevation":"9.1"
2018-08-16 19:55:00.662 "observation_location": {
2018-08-16 19:55:00.662 "full":"Kleine Brogel, ",
2018-08-16 19:55:00.662 "city":"Kleine Brogel",
2018-08-16 19:55:00.662 "state":"",
2018-08-16 19:55:00.662 "country":"BE",
2018-08-16 19:55:00.662 "latitude":"50.97",
2018-08-16 19:55:00.662 "longitude":"4.47",
2018-08-16 19:55:00.662 "elevation":"26 ft"
2018-08-16 19:55:00.662 "estimated": {
2018-08-16 19:55:00.662 "station_id":"IZEMST12",
2018-08-16 19:55:00.662 "observation_time":"Last Updated on August 16, 7:54 PM CEST",
2018-08-16 19:55:00.662 "observation_time_rfc822":"Thu, 16 Aug 2018 19:54:57 +0200",
2018-08-16 19:55:00.662 "observation_epoch":"1534442097",
2018-08-16 19:55:00.662 "local_time_rfc822":"Thu, 16 Aug 2018 19:55:00 +0200",
2018-08-16 19:55:00.662 "local_epoch":"1534442100",
2018-08-16 19:55:00.662 "local_tz_short":"CEST",
2018-08-16 19:55:00.662 "local_tz_long":"Europe/Brussels",
2018-08-16 19:55:00.662 "local_tz_offset":"+0200",
2018-08-16 19:55:00.662 "weather":"Partly Cloudy",
2018-08-16 19:55:00.662 "temperature_string":"76.8 F (24.9 C)",
2018-08-16 19:55:00.662 "temp_f":76.8,
2018-08-16 19:55:00.662 "temp_c":24.9,
2018-08-16 19:55:00.662 "relative_humidity":"64%",
2018-08-16 19:55:00.662 "wind_string":"Calm",
2018-08-16 19:55:00.662 "wind_dir":"NNW",
2018-08-16 19:55:00.662 "wind_degrees":330,
2018-08-16 19:55:00.662 "wind_mph":0,
2018-08-16 19:55:00.662 "wind_gust_mph":0,
2018-08-16 19:55:00.662 "wind_kph":0,
2018-08-16 19:55:00.662 "wind_gust_kph":0,
2018-08-16 19:55:00.662 "pressure_mb":"1014",
2018-08-16 19:55:00.662 "pressure_in":"29.95",
2018-08-16 19:55:00.662 "pressure_trend":"0",
2018-08-16 19:55:00.662 "dewpoint_string":"64 F (18 C)",
2018-08-16 19:55:00.662 "dewpoint_f":64,
2018-08-16 19:55:00.662 "dewpoint_c":18,
2018-08-16 19:55:00.662 "heat_index_string":"NA",
2018-08-16 19:55:00.662 "heat_index_f":"NA",
2018-08-16 19:55:00.662 "heat_index_c":"NA",
2018-08-16 19:55:00.662 "windchill_string":"NA",
2018-08-16 19:55:00.662 "windchill_f":"NA",
2018-08-16 19:55:00.662 "windchill_c":"NA",
2018-08-16 19:55:00.662 "feelslike_string":"76.8 F (26 C)",
2018-08-16 19:55:00.662 "feelslike_f":"76.8",
2018-08-16 19:55:00.662 "feelslike_c":"26",
2018-08-16 19:55:00.662 "visibility_mi":"6.2",
2018-08-16 19:55:00.662 "visibility_km":"10.0",
2018-08-16 19:55:00.662 "solarradiation":"79",
2018-08-16 19:55:00.662 "UV":"1.0","precip_1hr_string":"0.00 in ( 0 mm)",
2018-08-16 19:55:00.662 "precip_1hr_in":"0.00",
2018-08-16 19:55:00.662 "precip_1hr_metric":" 0",
2018-08-16 19:55:00.662 "precip_today_string":"0.00 in (0 mm)",
2018-08-16 19:55:00.662 "precip_today_in":"0.00",
2018-08-16 19:55:00.662 "precip_today_metric":"0",
2018-08-16 19:55:00.662 "icon":"partlycloudy",
2018-08-16 19:55:00.662 "icon_url":"http://icons.wxug.com/i/c/k/partlycloudy.gif",
2018-08-16 19:55:00.662 "forecast_url":"http://www.wunderground.com/global/stations/06448.html",
2018-08-16 19:55:00.662 "history_url":"http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IZEMST12",
2018-08-16 19:55:00.662 "ob_url":"http://www.wunderground.com/cgi-bin/findweather/getForecast?query=50.970974,4.465515",
2018-08-16 19:55:00.662 "nowcast":""
2018-08-16 19:55:00.662 Status: dzVents: Info: ------ Finished dzVentstestWU
Now i need only the code to filter the weather info out of the list
More to come
SweetPants
Please read the Wiki https://www.domoticz.com/wiki/DzVents:_ ... _scripting, you have to convert the JSON string using fromJSON(json) to LUA table first to be able to read the individual elements of the JSON string
Lebo2d9 wrote: Thursday 16 August 2018 20:02 This is the code I already have in dzVents
The recent versions of dzVents are much more sophisticated to handle URL's and returns.
Maybe the script example below gets you going.
-- getWeather.lua
    on =        {     timer           =   { "every hour" },
                        httpResponses   =   {  "Wunderground_response" } },
    logging =   {       level   =   domoticz.LOG_DEBUG,
                        marker  =   "getWeather" },
    execute = function(dz, triggerItem)
        local function getWundergroundData()
            local url   = "http://api.wunderground.com/api/myapikey/conditions/q/pws:IZEMST12.json"
            dz.openURL({    url         = url,
                            method      = "GET",
                            callback    = "Wunderground_response"
        local function handleResponse()
            local rt = triggerItem.json                        -- rt is just a reference to the data no actual copy is done
            if triggerItem.json ~= nil then
                dz.log(rt,dz.LOG_DEBUG)
                -- handle the response and fill your text device here
        if triggerItem.isHTTPResponse then
           if triggerItem.ok and triggerItem.isJSON then
               handleResponse()
               dz.log("Problem with response from wunderground",dz.LOG_DEBUG)
Lebo2d9
Post by Lebo2d9 »
Hi Waaren,
Thx for the code but now i get
2018-08-16 21:48:01.401 Status: dzVents: Debug: getWeather: {["current_observation"]={["relative_humidity"]="72%", ["visibility_mi"]="6.2", ["temp_c"]=21, ["history_url"]="http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IZEMST12", ["local_tz_short"]="CEST", ["precip_1hr_in"]="0.00", ["temperature_string"]="69.8 F (21.0 C)", ["dewpoint_string"]="60 F (16 C)", ["pressure_mb"]="1014", ["dewpoint_c"]=16, ["wind_kph"]=1.1, ["precip_1hr_string"]="0.00 in ( 0 mm)", ["wind_string"]="Calm", ["observation_time_rfc822"]="Thu, 16 Aug 2018 21:32:51 +0200", ["heat_index_string"]="NA", ["nowcast"]="", ["ob_url"]="http://www.wunderground.com/cgi-bin/findweather/getForecast?query=50.970974,4.465515", ["local_time_rfc822"]="Thu, 16 Aug 2018 21:33:00 +0200", ["precip_today_in"]="0.00", ["windchill_string"]="NA", ["windchill_f"]="NA", ["precip_today_string"]="0.00 in (0 mm)", ["image"]={["link"]="http://www.wunderground.com", ["url"]="http://icons.wxug.com/graphics/wu2/logo_130x80.png", ["title"]="Weather Underground"}, ["forecast_url"]="http://www.wunderground.com/global/stations/06448.html", ["icon_url"]="http://icons.wxug.com/i/c/k/nt_clear.gif", ["feelslike_string"]="69.8 F (21.0 C)", ["pressure_trend"]="0", ["icon"]="clear", ["precip_today_metric"]="0", ["wind_mph"]=0.67, ["dewpoint_f"]=60, ["precip_1hr_metric"]=" 0", ["weather"]="Clear", ["local_epoch"]="1534447980", ["UV"]="0.0", ["solarradiation"]="0", ["visibility_km"]="10.0", ["heat_index_c"]="NA", ["feelslike_c"]="21.0", ["estimated"]={}, ["wind_gust_mph"]="2.5", ["wind_dir"]="NNE", ["wind_degrees"]=14, ["windchill_c"]="NA", ["feelslike_f"]="69.8", ["heat_index_f"]="NA", ["observation_time"]="Last Updated on August 16, 9:32 PM CEST", ["local_tz_long"]="Europe/Brussels", ["station_id"]="IZEMST12", ["wind_gust_kph"]="4.0", ["pressure_in"]="29.95", ["observation_epoch"]="1534447971", ["observation_location"]={["country"]="BE", ["elevation"]="26 ft", ["city"]="Kleine Brogel", ["latitude"]="50.97", ["country_iso3166"]="BE", ["full"]="Kleine Brogel, ", ["state"]="", ["longitude"]="4.47"}, ["local_tz_offset"]="+0200", ["temp_f"]=69.8, ["display_location"]={["magic"]="85", ["city"]="Weerde", ["state_name"]="Belgium", ["state"]="VLG", ["longitude"]="4.465515", ["elevation"]="9.1", ["zip"]="00000", ["latitude"]="50.970974", ["country_iso3166"]="BE", ["wmo"]="06448", ["country"]="BX", ["full"]="Weerde, Belgium"}}, ["response"]={["version"]="0.1", ["termsofService"]="http://www.wunderground.com/weather/api/d/terms.html", ["features"]={["conditions"]=1}}}
2018-08-16 21:48:01.401 Status: dzVents: Info: getWeather: ------ Finished dzVentstestWU
My only problem is how do i get only the weather info
More to come
Lebo2d9 wrote:Hi Waaren,
What do you see if you change dz.log(rt,dz.LOG_DEBUG)
to
dz.log(rt.current_observation.weather,dz.LOG_DEBUG)
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Lebo2d9
Post by Lebo2d9 »
Hi waaren,
Thx for the last update
now i get what i want
018-08-17 11:56:01.349 Status: dzVents: Info: Handling httpResponse-events for: "Wunderground_response
2018-08-17 11:56:01.349 Status: dzVents: Info: getWeather: ------ Start internal script: dzVentstestWU: HTTPResponse: "Wunderground_response"
2018-08-17 11:56:01.369 Status: dzVents: Debug: getWeather: Partly Cloudy
2018-08-17 11:56:01.369 Status: dzVents: Info: getWeather: ------ Finished dzVentstestWU
More to come
roseen
Post by roseen »
Note that the Weather Underground API will stop working 2018-12-31 as the service is being discontinued.
end-of-service-for-the-weather-underground-api:
https://apicommunity.wunderground.com/w ... ground-api
SweetPants
Not 100% true:
For developers who use WU API data for non-commercial purposes, you will have access to a new plan for a personal use, low call volume API. Stay tuned for more details as we build this out.
Let's wait what they come up with
