get power value and gas value from a json
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
I try to make a LUA script.. Didn't see whats wrong, why Domoticz don't update my sensor.
    powerUsage = uservariables['UV_StroomSensorName']
    ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
    json = assert(loadfile "/home/domoticz/scripts/lua/JSON.lua")()  -- For Raspberry
    local handle = assert(io.popen(string.format('curl http://%s/happ_pwrusage?action=GetCurrentUsage', ToonIP)))
        local jsonInfo = handle:read('*all')
    handle:close()
    jsonInfo = string.gsub(jsonInfo, ",}", "}")
    jsonInfo = json:decode(jsonInfo)
    powerUsage = tonumber(jsonInfo.powerUsage.value)
    -- Update the power sensor to current usage
    if otherdevices_svalues[powerUsage] ~= powerUsage then
        print('Updating power sensor to new usage: ' ..powerUsage)
        commandArray[1] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[powerUsage], powerUsage)}
All uservariables are ok. Link is my Toon Thermostat, give this in the browser:
{"result":"ok",
"powerUsage": {"value":183, "dayCost":0.97, "avgValue":550.61},
"powerProduction": {"value":0, "dayCost":0.00, "avgValue":0.00},
"gasUsage": {"value":25, "dayCost":0.32,"avgValue":6.22}
How can i read this in domoticz, i mean powerUsage value and gasUsage value?
Anyone can build a fast processor. The trick is to build a fast system.
jvdz
Domoticz version: 4.107
Re: get power value and gas value from a json
Post by jvdz »
You are using the variable powerUsage for both the devicename and the actual value, so the deviceupdate first parameter doesn't contain the proper IDX, since the name is changed to the found consumption value.
Jos
mAiden88
Post by mAiden88 »
jvdz wrote: Sunday 05 August 2018 10:46 You are using the variable powerUsage for both the devicename and the actual value, so the deviceupdate first parameter doesn't contain the proper IDX, since the name is changed to the found consumption value.
Jos
If I understand you correctly, should I change devicename? But still come Domoticz with this error message
2018-08-05 11:06:34.021 Error: EventSystem: in StroomGasToon: [string "commandArray = {}..."]:21: attempt to concatenate global 'powerUsage' (a nil value)
2018-08-05 11:06:44.054 Error: EventSystem: in StroomGasToon: [string "commandArray = {}..."]:21: attempt to concatenate global 'powerUsage' (a nil value)
jvdz
Post by jvdz »
No, the variable you use to store the devicename in your script. Something like this:
    powerUsageName = uservariables['UV_StroomSensorName']
    handle:close()
        commandArray[1] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[powerUsageName], powerUsage)}
Jos
mAiden88
Post by mAiden88 »
jvdz wrote: Sunday 05 August 2018 11:13 No, the variable you use to store the devicename in your script. Something like this:
    handle:close()
Jos
Thanks Jos. That one is working. I feel a bit stupid. So small mistake.
Now look if i can convert this one to import gas usage
