Run script every min, but only when a switch is on.
sion
Post by sion »
Hi.
I have just started looking a moving my lua and blockly to dzvents.
I was just wondering something about the triggers.
If I have
On
Timer : every 1 minute
Switch : my-switch
Will this run the script every min, AND when the switch is switched?
I am hoping to only run the script WHEN the switch is on.
So something like
On: timer: every minute ( when switch ==on).
Is it possible to do it in the top trigger section?
I know it will be possible to run the script every min, and then inside the execute section have:
If switch=on then
Do stuff....
End.
But I am trying not to have too many scripts running every minute.
Thanks.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Andyf66
Re: Run script every min, but only when a switch is on.
Post by Andyf66 »
Not sure dzvents does what you’re looking for, but my proposed extension would help. You could have a script that only is triggered by the switch, but then fires off a 1 minute timer to re-trigger itself.
viewtopic.php?f=59&t=24022&p=185214#p185214
dannybloe
Post by dannybloe »
It doesn't matter if you add some functionality to the on-section because domoticz only has a timer trigger that triggers every minute. So that's what dzVents gotta work with. All the checking for state of devices is done on the Lua side (in dzVents).
Having said that... just make an every-minute timer and check inside your execute function. If you don't want to do that, create a timer function and check in there (see the doc about this). But basically it's all the same.
sion
Post by sion »
Thanks for the clarification.
I think I’ll set a timer for every min, and then check to see if the switch is on inside the execute.
How many scripts can you have Running every min before it would start to have an impact on a rasp pi?
I’m probably worrying about nothing.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
sion wrote: Sunday 05 August 2018 20:10 Thanks for the clarification.
I have > 20 and no significant impact.
