Natatmo .temperature does not work
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
my Netatmo weather station delivers the following data:
dzVents: Info: 33.8;36;1
where 33.6 is the temperature, 36 the humidity (and 1 I do not know).
now how can I separate those 3 values in dZVents to lets say do something when the outside temperature is to high or low,...the humidity ...and so on..
many thanks
Joachim
elmortero
Domoticz version: 3.9639
Re: separation of different values
Post by elmortero »
Third value is probably dewpoint.
About getting the different values: If your sensor shows in the web-interface the values as temp/humidity you should check out this part of the dzvents documentation:https://www.domoticz.com/wiki/DzVents:_ ... C_Humidity
