hello,
I've just started to see if Domoticz is the right tool for me.
My first impression is very good.
I've connected a BME280 sensor with an ESP8266 through a LAN connection with Domoticz and it seems to work well.
The device is setup as a Temperature/Pressure/Humidity sensor and these values are nicely split by Domoticz.
Now I want to see the history of yesterday of this sensor but I can not find them in the database.
Are these values not stored in the database or am I looking at the wrong place ?
best regards,
Stef
are sensor values stored in the database ?
- waaren
Re: are sensor values stored in the database ?
Using the GUI you can just press the log button on the device to look at the history graphs.Stef wrote: Thursday 02 August 2018 17:52 ...
best regards,
Stef
In the domoticz.db you will find the device with current values in table DeviceStatus.
The history is stored in table Temperature with a granularity of 1 sample per 5 minutes (1-7 days definable in [SETUP][SETTINGS][LOG HISTORY])
and in table Temperature_Calendar where you will find the history with a granularity of 1 sample per day.
the ID in table DeviceStatus links to the DeviceRowID in the history tables.
Stef
thanks for the fast response.
ok one step further.
Yes I know the graph view from the GUI.
And yes I've seen the temperature table (but in that table the temperature value from Wunderground is shown.
I guess my problem is that I've 5 different temperature sensors, and I guess that Domoticz only stores the history of just one.
No, no, looking in detail indeed all temperatures of all sensors are in the Temperature table.
But I still can't find Humidity and Barometric pressure, while I can see the last day graphs, last month graph of these parameters, so they must be somewhere in the database.
It's not really an issue, because the values are also send to an MQTT broker/logger.
Is there anywhere some documentation of how values in the database are stored ?
best regards,
Stef
best regards,
Stef
- waaren
Hi Stef in my domoticz database I see this for a combined device.Stef wrote: Thursday 02 August 2018 21:16 ...
.headers on
select * from temperature where deviceRowId = 1014;
DeviceRowID|Temperature|Chill|Humidity|Barometer|DewPoint|SetPoint|Date
1014|0.0|0.0|50|1010|-9.2|0.0|2018-08-02 20:40:00
Not that I know. I made a copy of the database and transferred it to my PC and peeked around using SQLiteExport personal edition (freeware)Is there anywhere some documentation of how values in the database are stored ?
Stef
thanks again Waaren,
they are indeed in the temperature table
(I used DBbrowser to view it,
SQLtiteStudio before, but that was far too slow, maybe therefore I missed it
best regards,
Stef
best regards,
Stef
