Openwebnet AREA 0 doesn't work
Posted: Thursday 02 August 2018 11:14
by Gigi79
<t>Good morning ,<br/>
I am writing this email since yesterday I tested your application integrated with the Openwebnet Bticino / Legrand system.<br/>
I have a small system with 15 lights, I used AREA 0 as a configuration, the problem is that your application on the environment 0 fails to correctly compose the Open code to send to the bticino gateway.<br/>
<br/>
Example :<br/>
<br/>
On Light 02 Correct -> * 1 * 1 * 02 ##<br/>
On Light 02 Domoticz -> * 1 * 1 * 2 ## => This command in OPENWEBNET is seen as an AREA 2 command and therefore the actuator does not activate.<br/>
<br/>
I hope that as a result of my report you can find a way to solve the problem.<br/>
<br/>
Greetings<br/>
Gigi</t>
Re: Openwebnet AREA 0 doesn't work
Posted: Wednesday 29 August 2018 17:11
by Gigi79
Can you anwser to my question please ?
Posted: Wednesday 28 August 2019 1:03
by spugna85
Hi Gigi79, can you check if you still have the same problem with the current version?
A solution could be to avoid using area 0, even if this means reconfiguring the system ...
In any case it may not be simply to distinguish in the code the area command with the command on a point of area 0.
