Openwebnet AREA 0 doesn't work
Gigi79
Post by Gigi79 »
<t>Good morning ,<br/>
I am writing this email since yesterday I tested your application integrated with the Openwebnet Bticino / Legrand system.<br/>
I have a small system with 15 lights, I used AREA 0 as a configuration, the problem is that your application on the environment 0 fails to correctly compose the Open code to send to the bticino gateway.<br/>
<br/>
Example :<br/>
<br/>
On Light 02 Correct -> * 1 * 1 * 02 ##<br/>
On Light 02 Domoticz -> * 1 * 1 * 2 ## => This command in OPENWEBNET is seen as an AREA 2 command and therefore the actuator does not activate.<br/>
<br/>
I hope that as a result of my report you can find a way to solve the problem.<br/>
<br/>
Greetings<br/>
Gigi</t>
Gigi79
Re: Openwebnet AREA 0 doesn't work
Post by Gigi79 »
Can you anwser to my question please ?
spugna85
Post by spugna85 »
Hi Gigi79, can you check if you still have the same problem with the current version?
A solution could be to avoid using area 0, even if this means reconfiguring the system ...
In any case it may not be simply to distinguish in the code the area command with the command on a point of area 0.
