[error] Too many lines  [Solved]
EdwinK
Post by EdwinK »
I'm getting the following error all of a sudden on a script: ' dzVents: Error (2.4.7): Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:1009: Lua script execution exceeds maximum number of lines'
This is the script:
		timer = { 'every 5 minutes' },
		httpResponses = { 'blitz' } -- matches callback string below
        data = {
            last = { initial = 0 }
	execute = function(domoticz, triggerItem)
	   local lightning = domoticz.devices('Bliksemteller')
	   local preLight = tonumber(lightning.rawData[1])
		distance = function(lat1, lng1, lat2, lng2)
		radius = 6371
		dLat = (lat2 - lat1) * math.pi / 180
		dLng = (lng2 - lng1) * math.pi / 180
		lat1 = lat1 * math.pi / 180
		lat2 = lat2 * math.pi / 180
		val = math.sin(dLat / 2) * math.sin(dLat / 2) + math.sin(dLng / 2) * math.sin(dLng / 2) * math.cos(lat1) * math.cos(lat2)
		ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1 - val))
		return radius * ang
		local latHome = 51.860069  --replace with your own coordenates
		local lngHome = 4.4122027  --replace with your own coordenates
		local distanceRange = 10   --change to the maximum distance you want for filtering (in KMs)
		local last = tonumber(domoticz.data.last)
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://www.onweeractueel.nl/domoticz_bo.json',
				method = 'GET',
				callback = 'blitz'
		elseif (triggerItem.isHTTPResponse) then
	local response = triggerItem
		if (response.ok and response.isJSON) then
			local value = 0
			local ignored = 0
			tl = #response.json
			tc = 1
			repeat
			local times = tonumber(response.json[tc][1])
			local lat = tonumber(response.json[tc][2])
			local lng = tonumber(response.json[tc][3])
			local distanceBetween = distance(latHome, lngHome, lat, lng)
			 if (distanceBetween <= distanceRange) then
				if (times > last) then
				 value = value + 1
				 value = 0
			  domoticz.data.last = times
			tc = tc + 1
			until tc > tl
			print('Blitz Value = '..value)
			if value ~= preLight then
			lightning.updateCustomSensor(value)
				print('**blitz failed to fetch info')
dannybloe
Re: [error] Too many lines
Post by dannybloe »
Mmm. Didn't know there was a max in de JSON.lua library. dzVents uses the one that comes with Domoticz.
EdwinK
Post by EdwinK »
I don't know anything at all about this, so I hope you have some ideas :)
Just noticed when doing something else, so maybe it was going on for a long time
EdwinK wrote: Sunday 29 July 2018 10:54 I don't know anything at all about this, so I hope you have some ideas :)
@EdwinK, this is a known problem and reported here
dannybloe
Post by dannybloe »
Well, appears that it is something in Domoticz. See also this topic.
I really have no idea why this is in the Domoticz code at all.
elmortero
Domoticz version: 3.9639
Post by elmortero »
I have been looking into this a lot and never found a solution/workaround. Never figured it was a limitation in Domoticz.
It does make sense in the way that you would not want the event system to hang.
In the case of the script mentioned by the OP, not rarely the json result is over 20000 lines long and I figure that it might take too long to process them all.
I have contacted the owner/admin of onweeractueel to see if the results can be filtered (by setting max/min lon and lat) but never got an answer to that.
Also investigating alternative providers, but there are not many, and the existing ones are rather expensive
elmortero wrote: Sunday 29 July 2018 12:39 I have been looking into this a lot and never found a solution/workaround. Never figured it was a limitation in Domoticz.
Seems indeed a hard coded limit in json_reader.cpp (stackLimit_g) to prevent a situation where a bad json could cause a segmentation fault.
If onweeractueel would extend their api with an option to filter the result on location and/or time, it would add more user control to the size of the response.
dannybloe
Post by dannybloe »
No it is not in json reader. We don’t use that. It is in EventSystem.cpp. Lua is doing the json parsing.
EdwinK
Post by EdwinK »
waaren wrote: Sunday 29 July 2018 12:09
Thanks. Didn't know that.
elmortero
Post by elmortero »
waaren wrote: Sunday 29 July 2018 12:09 @EdwinK, this is a known problem and reported here
Yes, but I never got a response..
Greetz,
Oli
Re: [error] Too many lines  [Solved]
elmortero wrote: Sunday 29 July 2018 20:43
Greetz,
Oli
@EdwinK, @elmortero, today the question was bumped and we received a reply !
"At this moment we are rebuild the script where an api is do the job where you can receive based on a unique location the info in place of all the unrelated info."
EdwinK
Post by EdwinK »
Great :)
Thanks for the feedback.
phoenixblue
Post by phoenixblue »
I see you are using the script inside dzVents I'm correct?
EdwinK
Post by EdwinK »
Yes, I use the dzVents script.
phoenixblue
EdwinK wrote:Yes, I use the dzVents script.
I have no experience to tell you if this script is working inside it because it's build for outside it.
EdwinK
Post by EdwinK »
Going to try your script as now and put elmortero's on hold
