Display Domoticz messages on your Philips TV
pepijn
Post by pepijn »
A nice addition to my Domoticz installation:
Display messages on my TV screen on certain events (door opens, doorbel rings etc)
This is possible using JointSpace and a simple bash script on my Raspberry Pi.
First download JSTx (http://sourceforge.net/apps/mediawiki/j ... title=JSTx)
I've copied the binaries to /opt/JSTx
Create a script (i named it display.sh)
/opt/JSTx/JSTx -F /opt/JSTx/font/decker.ttf -s 40 -W 1280 -H 720 -w 1200 -h 60 -x 40 -y 40 -t "$*" t -T 5 -b "100,100,100,128" -f "255,255,255,255" --dfb:quiet --remote=<TV IP address>
You can use the script on the switch configuration page, on or off action.
script:///opt/domoticz/scripts/display.sh This message will be displayed on your TV
You can also use it in LUA scripts if you want.
Have fun!
Pepijn
Derik
Re: Display Domoticz messages on your Philips TV
Post by Derik »
Only Philips???
Who tf owns a Philips.....?
remb0
Post by remb0 »
Me :). See my other post for a webbased tv remote.
@topicstarter: Great news. Van You put it in the wiki?
Maybe with download and copy commands??
BigDog
Domoticz version: V3.9269
Post by BigDog »
Das it work with samsung smart tv?
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
pepijn
Post by pepijn »
Nope, as far as i know only Philips uses JointSpace.
Derik
Post by Derik »
remb0 wrote:Me :). See my other post for a webbased tv remote.
Please where, i can not find , sorry [ the search on the site give no solution ]
pepijn
Post by pepijn »
Derik wrote:Please where, i can not find , sorry [ the search on the site give no solution ]
Try searching for "Philips" and you will find this post http://www.domoticz.com/forum/viewtopic.php?f=31&t=1150
Peter112
Post by Peter112 »
a little help i found and want to share
http://jointspace.sourceforge.net/download.html
below you can download jointSPACE TV simulator
more info, can we send json directly to the tv ?
for the users Smart-TV's, about 27% sold tv's in Holland is Philips, Samsung 41% Sony 11% ,Lg 10% and Panasonic 7%
RaspberryPI domoticz, test server Intel Atom 230 dual core @1,6 GhzW7-32bit domoticz Test,RFXtrx433 USB, Kaku ,OWL
pepijn
Post by pepijn »
The Philips TV's have a REST API running on a internal webserver on port 1925.
This example pushes the 'on/off button' on your remote.
curl -X POST -H "Content-Type: application/json" -d '{ "key": "Standby"}' http://<tv's ip address>:1925/1/input/key
I've put this into a bash script and calling this script from Domoticz as mentioned above.
The only problem i have right now is that i'am unable to detect the current state of the TV. So i don't know if it's turned on or off using the remote.
remb0
Post by remb0 »
sorry for my late responses. but here are the sources of websites i found on internet moths ago
TV Website.zip
(977.49 KiB) Downloaded 236 times
jec_44
Post by jec_44 »
I've seen something interresting for TV Samsung owner like me : http://tech.shantanugoel.com/2013/07/14 ... ython.html
It's a python script, easy to implement. Try it and give us your feedback ! :)
Jec
Brutus
Post by Brutus »
pepijn wrote:A nice addition to my Domoticz installation:
Have fun!
Pepijn
Do you think this is possible on a windows installation of domoticz?
You say I can use it in LUA. Is the script then te same or do you need to edit some things?
I have two Philips TV's so this could be nice :)
I also was wondering if I you can send commands like on, off, change source like in the MyRemote app from philips?
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
CronoS
Post by CronoS »
Hi, somebody knows if I can use this JSTx package on a Synology with DSM 6? And how to enable this?
I am not really familiar with Linux. I want to control my 2010 Philips with this, that should work with the 0.23 JSTx package?
twoenter
Domoticz version: 4.10
Post by twoenter »
CronoS wrote: Wednesday 29 June 2016 21:10 Hi, somebody knows if I can use this JSTx package on a Synology with DSM 6? And how to enable this?
Hi Cronos
I have Synology too and I don't use JSTx for sending commands but just the REST API. You can read how I have implemented it in my blog:
https://www.twoenter.nl/blog/domotica/s ... -domoticz/
Blog is dutch but you can translate it with google translate.
I want to display messages at my Philips TV is it possible to run JSTx at synology? We have no make commands available at DSM..
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
Wous
Post by Wous »
I used the JSTx tool in the past, I bought a new tv, so I cleaned the rubbish. Then my kid broke my new tv with some wood, so I reused my philips tv. Now I want to use the JSTx tools again, but somehow, it won't work. When I use the correct display script, I get this reply:
(#) DirectFBError [DirectFBCreate( &dfb )]: Appropriate item not found!
Fail!! err!=DFB_OK(!) [32311:    0.000] --> Caught signal 11 (at 0x50, invalid address) <--
./tekstintv.sh: regel 1: 32311 Afgebroken              /opt/JSTx/JSTx -F /opt/JSTx/font/decker.ttf -s 40 -W 1280 -H 720 -w 1200 -h 60 -x 40 -y 40 -t "$*" t -T 5 -b "100,100,100,128" -f "255,255,255,255" --dfb:quiet --remote=192.168.11.53:1925
Ip is correct2, I got no clue...
thanks.
