Blind Bathroom Fan Control
emme
Domoticz version: latest
Post by emme »
Ciao,
while I'm restructuring my bathroom, I played around with Zwave and other devices....
The result is an automatic fan control based on light and humidity
the actors are:
- Light switch (in my case zWave)
- Fan Switch (in my case zWave)
the sensors are:
- Temp/Humidity Device (in my case a rf433 device from Oregon)
The other stuff needed are:
- Numeric Variables with the Humidity Trigger (min/max)
How it works:
When you switch on the light the fan start, when the light is OFF or have been switched off the script evaluate the humidity value and act the fan accordingly
If over the MAX value it switch it on
if below the min value it switch off
the triggers are:
- light device
- Temp/Hum change
SCRIPT:
-- ======= SETUP =======
-- Place the correct names for devices and variables
local devFan     = 'Ventola_Bagnetto'   -- Fan Switche Device Name
local devLuce    = 'Luce_Bagnetto'      -- Light Switch Device Name
local varHMax    = 'bagnettoHumMax'     -- Variable Name for Max Humidity
local varHMin    = 'bagnettoHumMin'     -- Variable Name for Min Humidity
local devTempHum = 'TEM_Bagnetto'       -- Device Name for Temperature Device
-- Do Not Change Nothing beyond this point
function evalFan(dz, humMax, humMin)
    if dz.devices(devTempHum).humidity > humMax then
        dz.log('Umidità sopra il valore impostato.... accensione')
        dz.devices(devFan).switchOn().checkFirst()
    elseif dz.devices(devTempHum).humidity <= humMin then
        dz.log('Umidità sotto il valore impostato.... spegnimento')
        dz.devices(devFan).switchOff().checkFirst()
		devices = {	devTempHum, devFan, devLuce }
    logging = {
        level = domoticz.LOG_INFO,
        marker = "[BAGNETTO Ventola]"
	execute = function(dz, devName)
		local humMax = dz.variables(varHMax).value
		local humMin = dz.variables(varHMin).value
		if devName.name == devLuce and devName.state == 'On' then
		    dz.log('Accensione Luce Bagno ==> Ventola ON')
		elseif devName.name == devLuce and devName.state == 'Off' then
		    dz.log('Spegnimento Luce Bagno ==> Valutazione')
		    evalFan(dz,humMax,humMin)
		elseif devName.name == devTempHum and dz.devices(devLuce).state == 'Off' then
		    dz.log('Variazione T e H ==> Valutazione')
I've installed it 2 days ago and seems to work fine
hope you will find it useful!
caio
M
"We always done this way"
