I don't know why it doesn't work
Posted: Tuesday 17 July 2018 21:31
by pascal
Who could explain to me why it does not seem to work. Here is my script:
timer = { 'every minute' }
execute = function(domoticz, timer)
if (device'Fin_chauffage'.state == 'On')
then
device'prise ordi'.switchOff()
device'prise TV Chambre'.switchOff()
domoticz.notify('Hey pas mal')
device'prise TV Chambre'.switchOn()
device'prise ordi'.switchOn()
Thanks for your help
Pascal
Re: I don't know why it doesn't work
Posted: Tuesday 17 July 2018 22:14
by waaren
You missed a couple of () in your code. Do you see anything in the domoticz logfile ?
Please use code tags around your code to improve readability on the forum.
on = { timer = { 'every minute'} },
logging = { level = domoticz.LOG_ERROR,
marker = "chauffage actions" },
if (device('Fin_chauffage').state == 'On') then
device('prise ordi').switchOff()
device('prise TV Chambre').switchOff()
device('prise TV Chambre').switchOn()
device('prise ordi').switchOn()
Posted: Tuesday 17 July 2018 22:56
by pascal
No I don't see anything in logfile. even with yours. Amazing
Posted: Tuesday 17 July 2018 23:27
by waaren
pascal wrote: Tuesday 17 July 2018 22:56
Did you enable logging in your /etc/init.d/domoticz.sh ?
by removing the # on the line
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
so that it reads
Posted: Wednesday 18 July 2018 21:05
by pascal
I just did, but nothing happens. Probably something I did not do properly, but I don't know what.
Posted: Wednesday 18 July 2018 21:15
by pascal
Here is the error I have:
2018-07-18 21:10:56.190 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call global 'device' (a nil value)
Posted: Wednesday 18 July 2018 21:25
by waaren
pascal wrote: Wednesday 18 July 2018 21:15
We are getting somewhere now. Please try this modified script.
execute = function(domoticz, trigger)
if (domoticz.devices('Fin_chauffage').state == 'On') then
domoticz.devices('prise ordi').switchOff()
domoticz.devices('prise TV Chambre').switchOff()
domoticz.devices('prise TV Chambre').switchOn()
domoticz.devices('prise ordi').switchOn()
Posted: Wednesday 18 July 2018 21:40
by pascal
here it is:
2018-07-18 21:39:00.664 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call local 'device' (a table value)
Posted: Wednesday 18 July 2018 22:00
by waaren
pascal wrote: Wednesday 18 July 2018 21:40
here it is:
My mistake. I edited the previous post
Posted: Wednesday 18 July 2018 23:17
by pascal
any clue?
Posted: Thursday 19 July 2018 0:18
by waaren
pascal wrote: Wednesday 18 July 2018 23:17any clue?
Did you try the
edited version ?
the logic in your script causes dzVents to send you a notifications every minute for as long as "Fin_chauffage" state is On. It will also switch the other devices with a delay varying from 1 - 60 seconds. If you want to change the script in such a way that it triggers direct and only when the state of "Fin_chauffage" changes; modify it to:
on = { devices = { 'Fin_chauffage'} },
marker = 'chauffage actions' },
if trigger.state == 'On' then
Posted: Thursday 19 July 2018 13:59
by pascal
Thanks a lot Waaren. It is working exactly how I wanted. What is the difference between:
execute = function(domoticz, trigger) and execute = function(domoticz, Device)?
Thanks again.
Pascal
Posted: Thursday 19 July 2018 14:18
by jake
Thanks again.
Pascal
Please check the wiki:
https://www.domoticz.com/wiki/DzVents:_ ... gerInfo.29
There they use the word 'item'. It is your choice what word to use. In your script you didn't make use of the'trigger word', so you can skip it as well:
execute = function(domoticz)
Posted: Thursday 19 July 2018 15:35
by waaren
jake wrote: Thursday 19 July 2018 14:18
pascal wrote:What is the difference between:
@Jake, in the example based on the device state change trigger is used so better to leave it like it is.
@pascal, the the second parm in the function(domoticz,Device) (or function(domoticz,trigger) ) is the object that is triggering the script.
It can be a device, variable, scene, group, timer, security or httpResponse depending on what you defined in the on = (....) section.
Posted: Thursday 19 July 2018 19:02
by jake
@waaren, I based my comment on the initial scripts. Now I see in your suggested improved script (which I think is much better in this situation) that you used the 'trigger' in your script as intended.
