Split Temperature Humidity
Posted: Monday 16 July 2018 12:47
by terrorsource
I've already found a script that splits the TemperatureHumidty from my Aeotec MultiSensor6 into 2 dummy sensors:
-- Bathroom
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['MS_Badkamer_TempHum']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['MS_Badkamer_Temp'], tonumber(sensorTemperature)) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['MS_Badkamer_Hum'], sensorHumidity, sensorHumidityStatus) })
MS_Badkamer_TempHum = Aeotec MultiSensor 6
MS_Badkamer_Temp = Dummy Temperature
MS_Badkamer_Hum = Dummy Humidity
But this is constantly updating the dummy sensors, causing a lot of lines in the logs. I would like to have it update only when the value's of the seperate dummy sensors are different from the MultiSensor 6.
Can someone help me out with this?
Re: Split Temperature Humidity
Posted: Monday 16 July 2018 13:59
by emme
uh... are you sure
otherdevices_temperature['MS_Badkamer_Temp']
and
otherdevices_humidity['MS_Badkamer_Temp']
are not supported already for your device?
Posted: Monday 16 July 2018 14:32
by waaren
terrorsource wrote: Monday 16 July 2018 12:47
Something like ?
-- splitBathroomSensor
on = { devices = { "MS_Badkamer_TempHum"}},
logging = { level = domoticz.LOG_ERROR,
marker = "splitBathroomSensor" },
execute = function(dz, trigger )
local virtualTemperatureSensor = dz.devices('MS_Badkamer_Temp')
local virtualHumiditySensor = dz.devices('MS_Badkamer_Hum')
local masterTemperature = dz.utils.round(trigger.temperature,1)
local masterHumidity = dz.utils.round(trigger.humidity)
local masterHumidtyStatus = trigger.humidityStatusValue
local slaveTemperature = dz.utils.round(virtualTemperatureSensor.temperature,1)
local slaveHumidity = dz.utils.round(virtualHumiditySensor.humidity)
if slaveTemperature ~= masterTemperature then
virtualTemperatureSensor.updateTemperature(masterTemperature)
if slaveHumidity ~= masterHumidity then
virtualHumiditySensor.updateHumidity(masterHumidity,masterHumidtyStatus)
Posted: Monday 16 July 2018 17:33
by terrorsource
emme wrote: Monday 16 July 2018 13:59
uh... are you sure
and
No, Aeotec MultiSensor 6 does not have seperate sensors. Everyone who's using this sensor has this "problem".
waaren wrote: Monday 16 July 2018 14:32
Something like ?
Looks like it! Although i don't really get all of it but will take a look later this evening/tomorrow.
Posted: Sunday 28 October 2018 15:53
by terrorsource
I've now changed to a "Heiman Temperature Humidity Sensor HS1HT-Z+" from AliExpress but the script does not work.
Data of the sensor is "23.3 C, 54 %"
The script in the post above is only updating the Humidity and not the Temperature.
Posted: Sunday 28 October 2018 17:43
by waaren
terrorsource wrote: Sunday 28 October 2018 15:53
can you execute the dumpscript below and send the dump output (preferable via PM).
-- dumper
on = { devices = { "name of your new temperature sensor"}},
logging = { level = domoticz.LOG_DEBUG,
marker = "dumper" },
execute = function(dz, item )
item.dump()
Posted: Monday 29 October 2018 9:14
by terrorsource
waaren wrote: Sunday 28 October 2018 17:43
-- dumper
item.dump()
Script does not work.
Error: EventSystem: in dumper: [string "-- dumper..."]:7: attempt to index global 'domoticz' (a nil value)
Guess that is has something to do with "domoticz" "dz" use in the same script.
When i change them to the same, same error
Posted: Monday 29 October 2018 10:04
by waaren
terrorsource wrote: Monday 29 October 2018 9:14
No script is OK as it was. You should only enter the name of your device.
Are you sure you saved it as a dzVents script ?
