Split Temperature Humidity Topic is solved
terrorsource
Post by terrorsource »
I've already found a script that splits the TemperatureHumidty from my Aeotec MultiSensor6 into 2 dummy sensors:
-- Bathroom
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['MS_Badkamer_TempHum']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['MS_Badkamer_Temp'], tonumber(sensorTemperature)) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['MS_Badkamer_Hum'], sensorHumidity, sensorHumidityStatus) })
MS_Badkamer_TempHum = Aeotec MultiSensor 6
MS_Badkamer_Temp = Dummy Temperature
MS_Badkamer_Hum = Dummy Humidity
But this is constantly updating the dummy sensors, causing a lot of lines in the logs. I would like to have it update only when the value's of the seperate dummy sensors are different from the MultiSensor 6.
Can someone help me out with this?
emme
Domoticz version: latest
Re: Split Temperature Humidity
Post by emme »
uh... are you sure
otherdevices_temperature['MS_Badkamer_Temp']
and
otherdevices_humidity['MS_Badkamer_Temp']
are not supported already for your device?
"We always done this way"
terrorsource wrote: Monday 16 July 2018 12:47
Something like ?
-- splitBathroomSensor
    on =        {       devices   =   { "MS_Badkamer_TempHum"}},
    logging =   {       level   =   domoticz.LOG_ERROR,
                        marker  =   "splitBathroomSensor" },
    execute = function(dz, trigger )
        local virtualTemperatureSensor  = dz.devices('MS_Badkamer_Temp')
        local virtualHumiditySensor     = dz.devices('MS_Badkamer_Hum')
        local masterTemperature         = dz.utils.round(trigger.temperature,1)
        local masterHumidity            = dz.utils.round(trigger.humidity)
        local masterHumidtyStatus       = trigger.humidityStatusValue
        local slaveTemperature          = dz.utils.round(virtualTemperatureSensor.temperature,1)
        local slaveHumidity             = dz.utils.round(virtualHumiditySensor.humidity)
        if slaveTemperature ~= masterTemperature then
            virtualTemperatureSensor.updateTemperature(masterTemperature)
        if slaveHumidity ~= masterHumidity then
            virtualHumiditySensor.updateHumidity(masterHumidity,masterHumidtyStatus)
terrorsource
emme wrote: Monday 16 July 2018 13:59 uh... are you sure
and
No, Aeotec MultiSensor 6 does not have seperate sensors. Everyone who's using this sensor has this "problem".
waaren wrote: Monday 16 July 2018 14:32
Something like ?
Looks like it! Although i don't really get all of it but will take a look later this evening/tomorrow.
terrorsource
I've now changed to a "Heiman Temperature Humidity Sensor HS1HT-Z+" from AliExpress but the script does not work.
Data of the sensor is "23.3 C, 54 %"
The script in the post above is only updating the Humidity and not the Temperature.
terrorsource wrote: Sunday 28 October 2018 15:53 I've now changed to a "Heiman Temperature Humidity Sensor HS1HT-Z+" from AliExpress but the script does not work.
can you execute the dumpscript below and send the dump output (preferable via PM).
-- dumper
    on =        {       devices   =   { "name of your new temperature sensor"}},
    logging =   {       level   =   domoticz.LOG_DEBUG,
                        marker  =   "dumper" },
    execute = function(dz, item )
        item.dump()
terrorsource
waaren wrote: Sunday 28 October 2018 17:43
-- dumper
        item.dump()
Script does not work.
Error: EventSystem: in dumper: [string "-- dumper..."]:7: attempt to index global 'domoticz' (a nil value)
Guess that is has something to do with "domoticz" "dz" use in the same script.
When i change them to the same, same error
terrorsource wrote: Monday 29 October 2018 9:14 Script does not work.
No script is OK as it was. You should only enter the name of your device.
Are you sure you saved it as a dzVents script ?
