Power generated message
terrorsource
I have a SMA Converter for my solar panels, it's already connected in Domoticz via SBFspot so i can see the generated power.
The "Total generated" and "Generated today" are shown in the device under Utility.
Is it possible to receive a message when the generation of "today" has reached a value? like 20kwh.
terrorsource
Re: Power generated message
I've created a basic script now, sends a message when the counterToday is higher then 12.000 kwh.
LOG:
2018-07-12 14:00:21.828 Status: dzVents: Info: Handling events for: "SMA_SolarMain", value: "2390.000;13887088.000"
2018-07-12 14:00:21.828 Status: dzVents: Info: ------ Start internal script: SMA_generation: Device: "SMA_SolarMain (SMA)", Index: 115
2018-07-12 14:00:21.828 Status: dzVents: Info: ------ Finished SMA_generation
2018-07-12 14:00:22.005 Status: Notification: SMA_generation
Problem is that it sends a message each 5minutes (SMA refresh rate is at 5minutes) when the target is met.
Going to try to only send a message when there's no more generation and 20kwh or higher is generated;
"Usage" (which is realtime generation) = 0 and "counterToday" > 20
Getting to send the "result" of "counterToday" inside the message is the next step.
That can also send multiple messages but i dont have a clue to only send 1.
devices = {'SMA_SolarMain'},
if domoticz.devices("SMA_SolarMain").counterToday > 12 then
domoticz.notify("SMA Generated ","Generated 12kwh.", domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
MiloshCZ
Hi instead of "on device" use "on timer"
Your code:
new code:
But you need use "device(idx)" where "idx" is idx of your device (or you can use name of device)
Your code:
timer = {
-- timer triggers.. if one matches with the current time then the script is executed
'at 23:59',
domoticz.devices(idx).counterToday-
terrorsource
onTimer is not what i what, then it sends out a message at a certain time. I want to have it send a message when it can.
I've now created the script below.
Check's the counterToday, when it's above the numerToNotify it checks if the WhActual is zero, then it sends out 1 message.
When there's no power generation only one "0" value will be created by SBFspot at the end of the day.
At that time, DzVents script will pick it up and sends out a message with the total generated power of that day.
local sensorGenerator = 'SMA_SolarMain' -- fill in the sensor name which generated the power
local numberToNotify = 20
devices = {sensorGenerator},
local returnToday = domoticz.devices(sensorGenerator).counterToday
local returnCurrent = domoticz.devices(sensorGenerator).WhActual
if returnToday > numberToNotify and returnCurrent == 0 then
domoticz.notify('SMA Generated','Power generated today: '..returnToday, domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
rrozema
You can add a data section to your script, and in this section define a variable to hold the date the last message was sent. The value of the variables in the data section are stored after your script ran and restored before your script runs the next time.
Now whenever the script runs due to a device trigger and the value is at or above numberToNotify, you can check the date in this variable: only if it is before today's date you send out a message and then update the variable to today's date. The next time the device trigger runs again, value will still be over numberToNotify, but the date will be today's so no more messages will be sent.
B.t.w. I never done this myself in DzVents, so I have no example, but I suggest to store utc time in the persistent data, not local time, or you will get 2 notifications when daylight saving time (dutch: "zomertijd") changes.
terrorsource
Guess that makes the script "too much" and this is the first script i created myself so im proud enough at the momentrrozema wrote: Friday 13 July 2018 10:29 You can add a data section to your script, and in this section define a variable to hold the date the last message was sent. The value of the variables in the data section are stored after your script ran and restored before your script runs the next time.
It only sends out 1 message so far i can think off, haven't got a message today (17kwh) so will test out the next couple of days when there's 20kwh generated.
terrorsource
How do i create that dataset in the script i created?rrozema wrote: Friday 13 July 2018 10:29 You can add a data section to your script, and in this section define a variable to hold the date the last message was sent. The value of the variables in the data section are stored after your script ran and restored before your script runs the next time.
I got multiple messages this evening, each 5minutes.
2018-07-14 21:55:22.110 Status: Notification: SMA Generated
2018-07-14 22:00:22.263 Status: Notification: SMA Generated
2018-07-14 22:05:22.364 Status: Notification: SMA Generated
2018-07-14 22:10:21.518 Status: Notification: SMA Generated
- waaren
with datasection defined with history = true (explained in wiki here) and check on time, it looks like something belowterrorsource wrote: Saturday 14 July 2018 22:20How do i create that dataset in the script i created?rrozema wrote: Friday 13 July 2018 10:29 You can add a data section to your script, and in this section define a variable to hold the date the last message was sent. The value of the variables in the data section are stored after your script ran and restored before your script runs the next time.
on = { devices = {sensorGenerator} },
data = { notificationSent = { history = true, maxItems = 1 }},
local messageSent = domoticz.data.notificationSent.getLatest()
if not(messageSent) or not(messageSent.time.isToday) then -- not(MessageSent) for the case where data is not yet created)
domoticz.data.notificationSent.add('Power generated today: '..returnToday)
}Debian buster, bullseye on RPI-4, Intel NUC.
