Problem with selector with buttons
Posted: Wednesday 11 July 2018 13:02
by bregelius
Hi everybody,
i have a problem when trying to add a switch which has a button set or a selection menu with buttons. When i place a dimmer there is no problem, but if i change the switch to a "selector" i obtain at dashticz a text string instead of the buttons. For example, in the attached image , that switch is a selector with buttons (OFF, Low, Medium, High) and what i`m obtaining at dashticz is a text string, only one... I have been searching a lot in the forum, but i didn`t find a similar problem. Can anybody can help me? I have attached two pictures (one with dashticz's problem and one with original switch as shown and fully working with domoticz)
Thnx in advance
Re: Problem with selector with buttons
Posted: Thursday 12 July 2018 22:28
by HansieNL
Can you clean your browser cache and try latest Dashticz beta?
Problem should then be solved.
Posted: Monday 16 July 2018 18:44
by bregelius
HansieNL wrote: Thursday 12 July 2018 22:28
Thank you for your answer... i have tried that solution, with different browsers even a different computer (i’m using domoticz for windows) and still no solution.....
Posted: Monday 16 July 2018 21:35
by felix63
I have the same problem occurring. But I don't think the problem is specific to Dashticz. The same thing happens when looking at the switches in Domotix or Pilot on my iPhone . Only the Domoticz app shows the selector switches correct. Also see
viewtopic.php?f=6&t=24181
So probably something is changed in how the values are passed on and the Dashticz/Domotix/Pilot need to be updated.
Posted: Tuesday 17 July 2018 9:51
by bregelius
felix63 wrote: Monday 16 July 2018 21:35
I think you are right.... after reading your comment, i downgraded to a previous version of domoticz (in other computer which is not running the domo server) and BINGO, buttons appeared in Dashticz where before i had a text string.... so it seems to be a "problem" of Domoticz as you said.
Posted: Saturday 21 July 2018 11:54
by Lorr
I have the exact same problem. Been searching for hours on the forum! Will try to change to an other version of Domoticz...
Posted: Wednesday 01 August 2018 19:50
by Ectholian
This is due to a change in the domoticz api. See my previous post about it:
http://www.domoticz.com/forum/viewtopic ... 04#p187204
Posted: Tuesday 21 August 2018 13:32
by Ierlandfan
I just changed js/version.js
from
var levelNamesEncodeVersion = '3.9476'; /* Domoticz version above this, level names are encoded *
To:
var levelNamesEncodeVersion = '3.7476'; /* Domoticz version above this, level names are encoded *
and it worked. 3.7.476 is arbitrary. It only has to be lower as your current version of Domoticz.
I was running Domoticz version 3.9464 so it seems that the versioning was a little off.
Posted: Tuesday 30 October 2018 8:26
by honselbonsel
Hi Ierlandfan,
i was searching for the named fiel in the dashticz folder and couldn´t find the line to change.
Were is the file located? and where should be normally the line be?
thank You
br
jens
Posted: Tuesday 30 October 2018 13:18
by honselbonsel
ok,
i´ve found the Solution.
As the api sends base64 encoded string this must be decoded in dashticz.
viewtopic.php?f=67&t=17427&start=380
Posted: Tuesday 30 October 2018 13:43
by Lokonli
Which Domoticz version do you use?
Posted: Friday 23 November 2018 9:18
by honselbonsel
i use:
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Posted: Friday 23 November 2018 9:42
by Lokonli
honselbonsel wrote: Friday 23 November 2018 9:18
i use:
Version: 4.9700
Are you using the beta version of Dashticz? It should be solved from beta 2.3.11 onwards.
The master version doesn't contain the fix yet.
Posted: Saturday 16 March 2019 17:09
by desertdog
I am using Domoticz Version: 4.10362
and I think the latest Dashticz (on load I see v2 and i did a git pull in my dashticz directory which updated 3 files)
I still have this problem with a selector that I see and base64 hash instead of the selectors. Is there any fix?
Posted: Sunday 17 March 2019 9:20
by Lokonli
desertdog wrote: Saturday 16 March 2019 17:09
You can check whether you are indeed using the beta branch of Dashticz, and not the master branch, in two ways:
* look in [dashticz folder]/version.txt
* Click on the settings icon in the Dashticz top bar, then on the info tab. It shows the Dashticz version.
Posted: Sunday 17 March 2019 10:33
by desertdog
I am using version V2.3.3
Should things work with this version or do I need the beta? And if so, how do I upgrade to the beta
Posted: Sunday 17 March 2019 11:49
by Lokonli
desertdog wrote: Sunday 17 March 2019 10:33
You need the beta.
For upgrading it's best to install the beta version in a new folder and then copy your custom/CONFIG.js from your current Dashticz to the new one.
Most things are explained in the wiki:
https://www.domoticz.com/wiki/Dashticz_ ... stallation
Probably you have to make some additional changes to your CONFIG.js. For instance the fontawesome icon names have changed: you have to put far or fas in front of the icon names.
