I can't find the Radiator1 protocol in Domoticz RFCtrx433 hardware. What do I have to do?
How to enable smartwares radiator valve via RFXtrx433
- cyberclwn
Re: How to enable smartwares radiator valve via RFXtrx433
Underneath the hardware off your RFX there should be a "Smartwares Radiator".
If you scroll down the "Type" all the way, then in the active list, half way, it should be there.
If you select that type, it will become "Radiator 1" in the hardware list
Hope this helps.
Hope this helps.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
Thanks for the replay. Well thats what I expected aswell but I don't see it in the hardware list. When I connect tot the RFXmanager I can't see it eather. It is possible to transmit something with the protocol but it is not in the list. I use the RFXtrx433E with the latest ext/1025 release.
