Request: Lua script can read settings
jagroeneveld
Post by jagroeneveld »
I'd like to be able to read the settings using lua. Especially the location settings are of interest to me.
I know I could use json, but since I protected my Domotic, I have to use a userid/password in the script which I don't like for some reason.
Nice to have:
location = settings['location'] (as a line in a lua script)
from https://www.domoticz.com/wiki/Lua_-_json.lua (with change to use wget instead of curl):
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
--json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
read = os.execute('wget '..tempfilename..' http://localhost:<port>/json.htm?type=settings')
file = io.open(tempfilename, "r")
settings = file:read('*all')
file.close()
location = json:decode(settings)
lat = jsonLocation.current_observation.display_location.latitude
lon = jsonLocation.current_observation.display_location.longitude
Re: Request: Lua script can read settings
jagroeneveld wrote: Tuesday 26 June 2018 18:40 I'd like to be able to read the settings using lua. Especially the location settings are of interest to me.
Not sure if you do not want password less access from local system either. That would be required for this dzVents / Lua script.
SETUP -> SETTINGS -> LOCAL NETWORKS (NO USERNAME/PASSWORD): 127.0.0.*
I use the approach as in this script in various other dzVents scripts and store the Latitude / Longitude in (Global) persistent data variables so that I only have to call the openURL once.
--[[ getLocation.lua
    on = {      devices         =   { "locationTrigger" },            -- Just a trigger switch to kick off script
                httpResponses   =   { "LocationResponse" }
    execute = function(dz, trigger)
        if trigger.isTimer or trigger.isDevice then
                dz.openURL({
                        url = dz.settings['Domoticz url'] ..  "/json.htm?type=settings",
                        method = "GET",
                        callback = "LocationResponse" })
            print("Latitude:  " ..trigger.json.Location.Latitude)
            print("Longitude: " ..trigger.json.Location.Longitude)
