I have a Fibaro Dimmer 2 working well with a 2 gang momentary switch to control on/off/dim for my lights using the s1 input on the dimmer.
I would like to use the other input on the Dimmer 2 (s2) in order to control another light (not physically connected) with the other gang on the switch.
As I understand the way you can achieve this is with the use of a scene?
I have successfully got this partially working so that when I press the switch it can turn on another light switch controlled via domoticz - all good
But the problem I have is trying to turn this light off. The scene only appears to detect the 'on' state of the switch via s2 on the dimmer.
I have managed to get the light to turn off with a double click of the switch but I would like it to just be a single click.
Does anyone have the same problems - can you help?
Cheers in advance,
Dave
